My truck latch broke
Username: Volfenhagking1600
I WILL be 15 Wangin
Post Number: 379
now everyone has access to steal my system...how would i ghetto rig sumthin up... i have a 93 gmc jimmy
Username: Adddisorder
West palm, Florida
Post Number: 3802
bolt it shut? or buy a new one, or remove your subs
Username: Nd4spd18
Southeast PA
Post Number: 913
1st generation S series trucks are known to have issues with the window/gate latch system.
What exactly is the problem with yours? Is it just the window that won't latch or is it the tailgate? If it's just the window, it may not actually be borken, and if so it's an easy fix....
I WILL be 15 Wangin
Post Number: 382
no..it latches its just that it wont lock...you can just open it and the window will come up then you can turn it the other way and the tailgate will come down
Username: Nd4spd18
Southeast PA
Post Number: 923
Oh I see. In that case, your lock cylinder probably needs to be replaced. Thats not a part you can pull from a junkyard since you need it to be matched to your keys.
If you do get a new one though, it's not hard to replace. You take off the trim panel from the tailgate, and pull back the plastic. Theres two rods that have clips connecting them to the lock. Take those off, then take off the big clip holding the cylinder onto the tailgate. It will pop right out.
I WILL be 15 Wangin
Post Number: 384
alright thanks
