A have the same problem again...
Username: Longbluesquid
Post Number: 131
we replaced orur eclipse head unit with a cd3000 saturday then when im driving today i hit a bump then the radio cuts off. its either the fuse, grownd wire or bad head unit anyone have ideas on what wrong.
Username: Nd4spd18
Southeast PA
Post Number: 912
Double check all your connections, if you suspect the fuse check it with a DMM. You can also try running a separate ground wire to the HU instead of using the one in the wiring harness.
