What Sub Is Louder
Username: Splsq
Chesterland , Ohio USA
Post Number: 23
Should i get a 12inch Kicker L5 or a 12inch Kicker CVX? They would both be in a ported box and the L5 would be on a kicker amp and the CVX would be on a PA amp. What u think?
Username: Ctmike
Ct.
Post Number: 3601
cvx is by far the better sub.
Username: Splsq
Post Number: 24
Well would the CVX sound pretty good on a Kenwood Class D mono amp with 850 watts RMS.
Username: Ctmike
Ct.
Post Number: 3602
depends what you consider sounding good. to me it's sq is o.k. and are you stuck on kicker subs, you could do better. and i'd stay away from kenwood amps, they really suck. alot of problems with them. have heard the excelon line is decent, but i still wouldn't take the chance.
Username: Mike_16
Burlington, Wisconsin Us
Post Number: 390
yea ctmike ure rite myne isnt even half a year old its about 4months and used about 10 hours of that time and its blown already il never buy one again
Username: 04redmach1
Columbus, GA USA
Post Number: 367
Carl, what kind of budget are you working with?
Kevin
Username: Splsq
Post Number: 25
my spendin limit is 400 for a box amp and sub
Username: Mrskullz1
get alpine type r for a sub....really great budget sub and can get plenty loud if powered right. and for amp look at hifonics....they have great budget amps as well. wiring will cost u really little and the box u can build urself. Just go to ebay for the amp.
Username: Splsq
Post Number: 26
well what better the alpine type r or a kicker CVX cause i found a cvx on sale for 140
Columbus, GA USA
Post Number: 368
Email me Carl.
lowhz01@yahoo.com
Kevin
Username: Splsq
Post Number: 27
ok i emailed u
Username: Kyle_lowe
Post Number: 203
get an assassin
Username: Nd4spd18
Southeast PA
Post Number: 886
CVX is better but it is definitely not the best for the money.
And PA amps are junk.
Username: Loudon
Post Number: 885
planet audio amps are junk ... ur wild ...
they arent top of the line .... but a budget amp its one of the better ones
Username: Mygame5982
?????? H-TOWN, TEXAS US
Post Number: 1403
yea planet audio isnt junk..
i have a vx1400d in my room..
that b!tch knock...i dont care what you say about the amp...i know for a fact its better then a memphis prd1000.1 because i had both
