BXI 1206D to soundstream 15's
Username: Sk8erjim
Scottsmoor, Florida U.S.
Post Number: 114
i just bought a hifonics BXI 1206D amp to power my two soundstream T4-15's. the amp is turning on but the subs arent even moving. can someone tell me what im doing wrong?
Username: Mmaudioconcepts
Murray, KY
Post Number: 90
check rcas they could be bad
Murray, KY
Post Number: 91
check lpf and gain settings
Username: Paogr
AthensGreece
Post Number: 92
That hifonics is small for 2 T4-15, but this isn't a reason that your subs aren't moving.
Probably you haven't set the gain correctly...
Username: Sk8erjim
Post Number: 115
lpf and gain are good.
Username: Sk8erjim
Post Number: 116
but i just cheacked the speaker wire with a test light and it didnt light up. so there is no power go from the amp to the subs.
Murray, KY
Post Number: 94
your sub output could be fried...go to a local shop and have them test the amp.it will cost like $5-10 unless you have to toold to do it yourself.make sure the rcas didnt come lose from the ehad unit also
