Sony's XSL123P5B 12" Subwoofers
Username: Aussie_99
Post Number: 10
I have 2 Sony's XSL123P5B 12" Subwoofers
an want to no if this amp will work. Sony's XM2002GTR 2-channel Car Amplifier 200W RMS x 2
The amps Spec's are:
Max Power (Watts): 1200
Ad Hoc Power into 4 ohms, THD%: 200 x 2, .1
Ad Hoc Power into 2 ohms, THD%: 250 x 2, .15
Bridged into 4 ohms, THD%: 500, .15
Signal to noise ratio (dB): 100
Frequency Response (Hz): 5 - 50k
Input Level Range (V) Line level input: 0.3 - 6
Input Level Range (V) Speaker level input: 1.2 - 12
Operating Voltage (V): 10.5 - 16
Current Drain at rated output (A): 48
Width (inch): 15-7/8
Height (inch): 2-1/4
Depth (inch): 10-7/8
Weight (Approximate): 11/6
The subs spec's are (each):
Speaker Size (cm): 30
Speaker Size (inch): 12
Peak Power (W): 1300
Rated Power (RMS, W): 380
Impedance (ohms): 4
Sensitivity (dB/W/m): 89
Frequency Response (Hz): 18-2,000
Mass (kg): 5
Mass (lb/oz): 11/0
d (mm): 250
d (inch): 9.8
Rdc (ohms): 3.3
Fs (Hz): 24.8
Qts: .37
Qes: .39
Qms: 7.02
Vas (Lit.): 86.7
Vas (Cu. ft.): 3.06
Mms (g): 162.1
Lvc (mH): 1.1
Xmax (mm): 5.7
BL (Tm): 14.1
Username: Trey4sports
Post Number: 710
i think youll be ok bud just make sure you match up Xplode subs with Xplode amps or else the subs might get fried
Username: 420alldaylong
Post Number: 1042
I agree been there done that.
Username: Johnfiac
IL My wangers b...
Post Number: 1868
I wouldnt give them subs any amp.. they plug into my wall socket :-)... just a FYI if you dont already know.... Sony is wayyyy overrated.
Underrated equiptment FTMFW!
