Looking for New Amp
Username: Pete_the_pup
Gaffney, Sc Usa
I have a pair of Power Acoustik FUBR-10. 600w rms 1800 peak dual 2 ohm V/C. I'm only using 1 now becouse I don't have room for two in my truck. (made my own sub tube ported and tuned to 39hz) I need some suggestions for a good 1 ohm stable amp to power just 1 of the subs. Money is an object so need to keep it in the $400.00 to $500.00 range.
Username: Oleg
Santa Monica, CA USA
Post Number: 443
Check out some crossfires and USamps on eBay.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4223
jbl gto1201.1 or kicker zx 1000.1
Username: Oleg
Post Number: 447
Careful with the kicker, it's 2ohm stable. If you end up using the 2nd sub in the future and wire them into a 1ohm load, you will need a 1ohm stable amp. That JBL is a good choice though.
Gaffney, Sc Usa
Thanks I'll check out the JBL. "later Guys" P t P
Gaffney, Sc Usa
Just looked at JBL, not good. According to their web site the GTO1201.1 is 2ohm stable not 1. so it's back to the search. Thanks anyway PtP
Username: Oleg
Post Number: 448
Right, but that amp actually puts out full power at 1 and 4 ohms. Since you have dual 4 subs, you can wire them to 4 ohms and it'll be fine. Here're some 1ohm stable amps that'll suit you:
ORION HCCA-D2400 (my personal choice for you)
JBL BPX1100.1
ED nine.1 (www.edesignaudio.com)
Gaffney, Sc Usa
OLeg, I just looked at the Orion and the ED nine.1 I like the ED, it fits my credit card a lot better. do you have any of their products and do you recommend them? PtP
Username: Oleg
Post Number: 449
Actually, you'll find the orion fits your credit card a lot better, it's $315 shipped on eBay:
http://cgi.ebay.com/ORION-HCCA-D2400-CLASS-D-MONOBLOCK-AMPLIFIER-2400W-AMP_W0QQi temZ300086213653QQihZ020QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
My friend has this series amp, it will never get hot even at 1ohm.
pssst...you can even try it at 0.5ohm and get away with it, but i don't recommend it haha
Gaffney, Sc Usa
I don't have access to a computer at home and my work computer has a firewall that prohibits Ebay. I'm kinda stuck ordering from mfg's or online stores. Bummer!!! But I appreciate your effort. Thanks PtP
Username: Juliob
Post Number: 4224
if it's one sub, then grab a 600w rms amp at 1 ohm. Orion 600d or hcca d1200 can do the job.
my bad up there..
Username: Oleg
Post Number: 451
ah ok, then ED nine.1 it is.
Gaffney, Sc Usa
Post Number: 7
Oleg, Actually I tricked the firewall, saw that Sonic Electronics was the seller, went to their web site and just ordered the Orion. thanks again PtP
Username: Oleg
Post Number: 452
Congrats! Let me know how you like it.
Username: Qbenjamin
Florida
Post Number: 280
I have that Orion HCCA2400 for sale $312 brand new in the box and staraight from the factory with the 2-year warranty. Let me know.
