Recommend me a setup
Username: Jlnick
Post Number: 10
im looking to replace the stock speakers in my 2000 toyota avalon, trying to spend in the 600-650 range. also im trying to go with some components but I dont know a whole lot about speakers or multi-channel amps. Should I go with one or two pairs of components all of one amp? I need some suggestions on what to do im really clueless when it comes to speakers
btw. they need to be loud but im looking for sound quality too(they need to play over a 13w6)
Username: Nd4spd18
Southeast PA
Post Number: 615
You need a good set of component speakers and a 2 channel amp.
Username: Jlnick
Post Number: 11
any recomendations for a good comp set for around 250ish? and an amp to power them?
Username: Nd4spd18
Southeast PA
Post Number: 619
Take a look at this list for an idea of what brands to look at:
https://www.ecoustics.com/electronics/products/articles/329117.html
Username: Jlnick
Post Number: 12
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3372
I've done some searching and I really like these. I know focal is high quality stuff but are these good? And can someone suggest me a nice 2 channel amp? Thanks
Username: Adddisorder
West palm, Florida
Post Number: 3497
iv got a directed viper 400.2 125x2@4ohms 125 shipped.
Username: Jlnick
Post Number: 13
http://sonicelectronix.com/item_1171.html
is this jl audio 300/2 too much power for those focals?
Username: Nd4spd18
Southeast PA
Post Number: 621
That amp is 150 watts per channel, way more than you need for those 60 watt speakers. You can't really have too much power, but you don't need that much.
Username: Alteraudiousa
Concord
Post Number: 1466
does the 600$ include amp also? I can get you some speakers if you'd like email me at sales@alteraudiousa.com
Username: Jlnick
Post Number: 14
well right now ive narrowed it down to those speakers but my mind could change, can someone please give me a few AMP SUGGESTIONS!!? lol thanks.
Username: Jlnick
Post Number: 15
and originally i wanted to replace all 4 speakers now i just want to replace the front so my budgets probly around the 400-450 range
Concord
Post Number: 1467
set of CDT HD-62 will do very well for you and also give you some money to buy dynamat or the sort to deaden your doors.
Username: Nd4spd18
Southeast PA
Post Number: 640
I second that
