A2100d
Username: Jjflipped
MI USA
Hey all I'm new here, but i just purchased the power accoustik a2100d.
It claims 2000w RMS @ 1ohm
do you agree with this statement?
also does anyone own this amp and can tell me the amperage pull and fuse ratings?
Username: James1115
Use a simple...
Post Number: 9387
thats PEAK power, don't expect anywhere near that amount of power from it.
Username: Nd4spd18
Southeast PA
Post Number: 715
If that rating is PEAK then you will probably get about 1000 watts RMS from it, if that. Power acoustick is not a good brand.
Username: James1115
Use a simple...
Post Number: 9392
I don't even think you will get that from it.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4233
well, rovin owns that amp. He uses it for tests and he says it's very reliable. He used to push two alpine type Rs and did the job. He says it puts between 1000-1200w rms, for the money i think is great, hard to say you can't find many things for that amount of money.
He said once that he ran it for many hours at 1 ohm (stable) and never shut down. So expect something decent...
Username: Oleg
Santa Monica, CA USA
Post Number: 507
It'll do the job, but only get it if you absolutely cannot spend a bit more for a better amp. The amps are reliable, yes, i used to run mine at 1ohm (before i knew anything about circuits) all day and it was only 2 ohm stable. However, don't expect crazy power from them, take 500-600W off the rated power on their amps.
Username: Jjflipped
MI USA
http://translate.google.com/translate?hl=en&sl=ko&u=http://www.car5d5.com/caraud io/product_info.php%3Fn%3DPowerAcoustik_A2100D%26products_id%3D986&sa=X&oi=trans late&resnum=2&ct=result&prev=/search%3Fq%3Da2100d%26hl%3Den%26safe%3Dactive%26cl ient%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:official%26hs%3DbTr
that site and a few others all show 2000rms @1ohm...
thats why i bought it... oh well...
will it be better than my power accoustik ps2-1600?
Username: Jjflipped
MI USA
not to mention i heard it was identical to the previous years pa2500d by planet audio...
and everything i heard about that amp was great.
and it was the same 2000rms @ 1 ohm
Username: Juliob
Post Number: 4236
PA mono amps are their best products.
Username: Jjflipped
MI USA
well ive been very happy with my power accoustik ps2-1600 2ch power series amp, so i guess this one, since the mono are the best, will be much nicer...
thanks for all the help guys!
