!!!!!!Can somebody..........anybody help me!!!!!!!!!1
Username: Krazzyboy44
Post Number: 49
i was looking at a couple of subs and i wanted to know which will have the most output and most durable really looking for something to be louder than my last two 15 m3's
lanzar opti1535d
power acoustik mofo 15
soundstream t-4 15
Username: Logan__tille
Imortal Box Building
Post Number: 6244
out of thoes..soundstream. Were thoes memphis M3's? What kind of amp do you have? Thoes M3s will get very loud. Maybe it was the box?..
Username: Oglejust
You aint bangin unless..., Il
Post Number: 1137
wow... u need some better choices... tell us how much u want to spend and what amp u have and we'll fix u up.
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 1198
What is your budget because I'm sure you can find something better for the money than any of the subs you listed above but if you're set on those,definately stay away from the power acoustik.
Post Number: 58
these are the subs that im mainly looking at cuz when i had my $79 pioneer premier subs i was turning heads so i want to get underdog subs
