What freq do u set ur HU at?
Username: Shade
Moxee, Wa U.S.
Post Number: 106
i'm curious what is the best, 50, 80, 110. i know it depends on the subs but i've been running 50 up till now...i think 80 is best or should i just turn it off and let the amp do it?
Username: N2audio
Lawrence, Ks USA
Post Number: 1218
at 50 you'd have to have some awfully nice mids seeing a lot of power to pick up the 60-70 stuff.
80 or the amp IMO.
Username: Adddisorder
West palm, Florida
Post Number: 3403
basically where you mids start to drop off sharp then cut them off a little befor that and the the sub run
Username: Shade
Moxee, Wa U.S.
Post Number: 108
i'm a bit confused, here's what i got, rf 6x9's in rear and hopefully after this weekend type 6.5 comps installed....50 sounds better IMO but it doesn't hit all the 110 freq. but at 80 it hits most of them but it sounds alil off or punchy i guess
West palm, Florida
Post Number: 3415
what slope do you use if you set it at 80hz is do it at least at a 18db curve
Username: Shade
Moxee, Wa U.S.
Post Number: 111
ugh 18db curve? lol is that a setting in my deck? pioneer 5800mp or w/e
West palm, Florida
Post Number: 3444
it might be i dont nkow iv got the 860 and it has alot more options. you might be able to set it onthat deck but im not postive, look in the manual it might just be standard 12db curve
