Parking Brake bypass for Pioneer AVH-P6800dvd
Username: Bulldogsm2008
Iowa City, Iowa
Post Number: 313
i have an Avh-p6800dvd and i want to bypass the parking brake sensor so i can watch tv when the parking brake isnt on. there is only one light green wire to bypass the unit so what should i do to bypass it? i tried just grounding it with the radio ground and that didnt work. what should i do? the manual says it has to be connected to the power supply side of the parking brake sensor
Username: Shouder
Wisconsin
Post Number: 157
find a better ground and try again. Hell splice it into your head units ground, that wont hurt it.
