Kinetik or xstatic batteries
Username: Turnmat
i am running six 12" alpine type R subs off of a MA audio hk4000d. At nearly 4000 watts rms my battery and alternator cant keep up also i have a five farad power acoustic capacitor. And i was wondering what would be the best for my system.
I am debating between two kinetik hkc2000 or either four xstatic 800 or four xstatic 400 batcaps. I am not sure what would be best any suggetions?
thanks,
matt
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 297
go with an ho alt i personally use excessive and have never had any problems but some people dont like em theres iraggi too
www.excessiveamperage.com i dont know iraggis site
Username: Adddisorder
West palm, Florida
Post Number: 3357
http://www.wickedcases.com/caraudio/charging.html
http://www.wickedcases.com/caraudio/capacitors.html
read both those links
Username: Nickb4247
Post Number: 233
In a up-to-par electrical system, a capacitor is best used for the isolation of distortion caused by AC ripple. This can add unwanted sound to the system as well as increase resistance in your grounding system.
Username: Turnmat
do you think a H/O alternator would be enough on its own or should a add a kinetik hkc2000 battery in the back?
West palm, Florida
Post Number: 3384
get the HO alt and put a kinetik maybe 1800 under the hood and add another in back if nessisary
