"err" display on car radio
Username: Jane3788
Hi,
Can anyone tell me, please, how to reset the radio to where I can put the code in.
It was saying "code" and I have that, but in the meantime someone mucked with it and caused it just to display "err" when it is turned on. Then it doesn't turn off again except by switching off the ignition. We have disconnected the battery again, but that hasn't reset it.
The car is a 2001 Nissan Pulsar.
Thanks for the time.
Username: Carguy
Post Number: 5960
Jane look under Disc Changer section. Here's the link, just click on it. There are lot of people with the same problem with Nissan.
https://www.ecoustics.com/electronics/forum/car-audio/137782.html
Username: Jane3788
Thanks Isaac,
I don't think there's a CD in it, but if it comes to it links to how to remove the unit may be helpful.
Much appreciated.
Username: Jane3788
OK, it's fixed.
The problem was that too many "attempts" were made with an incorrect number and it locked.
The solution was to leave the ignition switched to 'accessories' and leave the "err" display flashing for an hour. After that it reset to "code" so I could input the PIN and now it's fine.
Actually, had I discovered in the first place when I got the car that in the glovebox was an "Audio Systems Owner's Manual Supplement", all the necessary info was in that, but since I didn't, I have to say that Nissan customer service in Australia is EXCELLENT!
Username: Carguy
Post Number: 5962
Oh, you're from Australia? Most if not all the problems are in North America.
Glad you fixed yours.
