I'm doing an install today, could use help
Username: Impala63rag
DD 9512s , Orion d5000
Post Number: 575
I'm hooking up a system for a friend. He's got a couple 12's going in a older Buick. I know it's a noob question, but how do I get the hot wire through the back seat and where should I connect the ground?
Username: Bump05
CashMoney, 15 Hd3 USA
Post Number: 928
ground it somewehre in the trunk if you can on a metal to metal location like body and bolt but makes sure it gets a good metal location gots to sanded if its not, and the power just run it through ur firewall through ur trims in the car through till the trunk or run it underneath SECURE and drill through.
Username: Nd4spd18
Post Number: 331
Every car is different. You just have to pull up the carpet and take off the trim panels until you find a good place to run the wire.
Connect the ground to an unpainted metal surface, a rear seat bolt is a popular choice.
Username: J_baby15
Kentucky
Post Number: 1262
make sure u sand before u ground.
