Audiobahn 8000T or 8000V??
Username: Ulshy55
Post Number: 31
I'm trying to order he audiobahn 8000T but it was sold out of where i was trying to buy it from. Then i thought, since both the 8000T and 8000V are pretty much the same should i get the newer one? Will the newer one have more "kinks" in it? I'm not sure what the advantages would be for the new one over the old one. I have seen MANY reviews on the onld one and ppl love it. Only one bad review out of 50 or so. I can't find any reviews on the new once since it is new. Who knows?
Also, will either of these amps put significant drain on my battery? I will be running 400W at 4ohms
Username: Carguy
Post Number: 5928
If you can, go with 8000T, if not 8000V should do.
They're both class D amp, so it shouldn't put that much strain on your battery/alternator.
