Alt or cap?
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 337
i will be running 1000rms at 1ohm and i was wondering if i should get a alt or if a cap would be ok. I can get the cap for about a thrid of the price so that would be nice but if it is pointless to get a cap then i guess ill have to suck it up and get a alt
Username: 54danny54
KY More Wang Th...
Post Number: 3459
dont get a cap...get a alt, you can upgrade in the future if you get an alt
Nj US
Post Number: 3466
Caps are bandaids at best. They don't "produce" any power at all. Have to go to the source. Alt baby.
Username: Nd4spd18
Post Number: 292
The capacitor will put more of a load on your charging system not less. You need an HO alternator.
Read this:
http://www.wickedcases.com/caraudio/capacitors.html
http://www.wickedcases.com/caraudio/charging.html
Username: Nyyfan13
Fi SSD USA
Post Number: 3431
suck it up unfortunatly...alt is the best way to go
Username: Snarl2004
Post Number: 339
if i get a 200amp alt do i need anything else like a new batt
Username: Nyyfan13
Fi SSD USA
Post Number: 3434
for only 1k you shuold be fine with a 200A alt...
Username: Snarl2004
Post Number: 340
will my stock battery be fine
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 1805
should be fine, but it won't hurt anything to get red-top...also, that way you will have it if you ever upgrade, same as with alt.
