P300.1 1 ohm???
Username: Stevefrench
Post Number: 31
So i got a RF P3001 amp, its rated on the birthsheet at 404W RMS @ 2 ohm and 252W RMS @ 4 ohm, can i run this amp at 1 ohm??( im gettin a kicker comp vr should it be dual 4 or dual 2 ohm??) with this sub can i run my amp at 1 ohm?
Username: Ctmike
Ct.
Post Number: 3240
get a dual 4ohm vc sub.
Post Number: 34
and wire to 1 ohm, what will i be lookin at in terms of RMS @ 1 ohm on that amp and is it bad to run that low?
Username: Ctmike
Ct.
Post Number: 3242
not sure if that amp is 1ohm stable so you'll wire the sub to a 2ohm load.
Post Number: 38
and get round 400W rms, that should do it?
if i get the dual 2 ohm i can only wire that to 4 ohm and that owould be only 252 W RMS, so no good?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4069
no. Get the dual 4 ohm. Your amp will push it correctly
