Risk?
Username: Smoke05
Tucson, Arizona U.S.
Post Number: 106
im planning on buying 2 alpine type r 12" which are 500rms each, either the dual 2 ohm to conectem at 2 ohms or the dual 4 ohms to connect them at 1 ohm. so here is my question. it is there a risk on running the amp at 1 ohm? (the amp is 1 ohm capable)like burning my car or frying my amp?. i will be using 4gauge cable.
thanks
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 11554
there is no problem running the amp at 1ohm...
