$300 on two 12's
Username: Boxy_brown
Post Number: 33
So, I decided to go with two twelve's and run my amp at 2 ohms to keep from having to buy a new alternator, so I have $300 on two twelve's, I need them to be able to handle at least 625 rms and I need to be able to wire them to 2 ohms any suggestions would be very much appreciated, thanks.
Username: Nyyfan13
Fi SSD USA
Post Number: 3155
why two subs?
for one sub, i say dd2512
for 2, try:
dd1012
aa assassin
fi x
not sure on the VC configs of those 3 subs...have to check to make sure they can get wired to 2ohm
Post Number: 34
i dont know lol, i was going to go with 4, but didnt have the funds to get all the charging upgrades needed for 2500 rms. two just sounds like a nice round number would one be better ? the amp is 1250 @ 2 ohms btw
Username: Nyyfan13
Fi SSD USA
Post Number: 3157
oh its 1250 at 2 ohms?
that changes it then...i thuoght it was 625 at 2 ohms
try one:
fi Q
dd2512
Fi BL
many others tho too
Username: Thumping_corsica
Mi, Mi Unitd states
Post Number: 280
fi x's??? they dont even sell those anymore do they?
Username: Nyyfan13
Fi SSD USA
Post Number: 3158
supposedly they do...just not on the site...someone here said they do still
but if you have 1250 at 2 ohm to work with...dont get the subs i listed in my first post
Post Number: 36
sorry bout the mis info thanks, ill look in to those
Username: Matt12490
California USA
Post Number: 1591
also if you decide on a single sub set up look for the eclipse Ti.
2 type Rs (dual 2) will work also
Post Number: 37
eclipse ti is that the 12 or 15 if its the 12 is this it ?? http://cgi.ebay.com/Eclipse-Titanium-12-Subwoofer-NEW_W0QQitemZ180078220570QQihZ 008QQcategoryZ18803QQrdZ1QQcmdZViewItem
