Why is a slot port shorter than another type of port with the same tuning freq? and is a labrinth port same as a slot? and you think it will be ok to use the outside wall of the box as one of the walls of the port
use 3/4 inch wood. and the slot port length is short because the wall continues to act as a port... let me explain by drawing give me a second to draw it up....
