Speakers stopped working..........
Username: Mixmastaspig
Canada, Canada Canada
Post Number: 872
K well I was listening to my stereo in my winter beater and all of a sudden my speakers stopped working. I checked the amp and everything looked good, it was getting power, Ground is screwed into the chassis of my car (sanded down, no wires touching) fuse is fine, gains and dials have not changed and they have been set the same for like 7 months and my speakers crackle sometimes when I turn the player on and off...
I cannot figure out what it wrong with it. Could it be possible that my RCA's fell out or something up at my cd player? I was thinking that but I would have to go down and borrow some keys as my cd player is about 5 years old and I don't have the keys anymore.
thanks
Username: Oglejust
15 Inch Wanger Club Pr..., Il
Post Number: 728
my system stopped working the other day cuz it was really cold. when they warm up r the ok?
Post Number: 873
Nope, I live in Canada and they were running in -30 degree weather, we had a bout of it for about a week. It's now maybe -1 sometimes and they don't want to work.
thanks for the help though, any more ideas? As I am stuck
Username: Oglejust
Post Number: 730
lmao thats ur problem thats f@ckin cold!!!!!
<--- that has a nice ring to it.. Mr. Ogle :-)
Post Number: 874
Mr Ogle sounds like a preverted Mr Dressup............lol
but its warmed up and they still don't work, they worked in -30
Username: Oglejust
Post Number: 733
hey man... mike sounds preverted lol jm idk what to tell ya then.. try new rca's.. is ur amp powering on?
Post Number: 875
anyone else
Username: Adam_s
Post Number: 427
Is the amp powering on even...so I can figure out if its power or signal.
Username: Extrmndor3
Sit and Look pretty
Post Number: 3326
damn thats cold.
Username: Moey_g
SydneyAustralia
Post Number: 33
Sounds like an RCA problem...
Post Number: 876
The amp powers on just fine.
Username: Nyyfan13
Fi SSD USA
Post Number: 2815
that is damnn cold
Post Number: 877
Lol yeah, but I need my amp to work...its like +5 right now so its all good, but the speakers still dont work, and amp powers on.
Username: Blainew
Alpine type S 6.5 inch...
Post Number: 2136
one of your speaker wires has gotta be grouned or something....
also try to hook up another speaker to ur amp...make sure ur amp has output
Post Number: 878
Sounds good ,I will try that today then and reply if it does somthing or not.
Username: Blainew
Post Number: 2137
as long as u can get another speaker to be powered...then ur fine
a friend of mine had the same problem....looked at all his speakers and found out that somehow the copper of the wire was touching the metal of the car
Username: Carguy
Post Number: 5846
Use a DMM and measure your speaker wires. It should give you a resistance of 4ohms/2ohms etc based on your speakers. If you get 0ohms or nothing at all, then the wires are either loose or the speaker is blown.
Here's a quick test on your amp and speakers. Attach a short rca cable to your amp's input and touch the end with your finger. It should cause a hum or some kind of noise. If you hear that, then everything's good. If you hear nothing, then the speakers are blown or the amp's output could be shot. You just need to isolate the problem one at a time.
Post Number: 879
Awesome, thanks for the help
