SPL meter????
Username: Solobaric4life
Seminole, Al United states
Post Number: 35
hey does any1 know a website that has any spl meters?? i got a cheap 1 that goes to 140db bt i blew it lol, the only1 i know is www.spl.com, but if u do can u give me the website? thankyou
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 1654
nick, you didnt get it there, that site has nothing to do with SPL. btw, the one used at most comps is a TermLab but you're talking $700
Username: Alexv305
Tavernier, FL USA
Post Number: 563
www.splmeter.com they are pretty accurate actually.. i saw one be off by 1 or 2 dBs compared to the Term Lab... They just dont read really low frequencies as well such as 20 to 30hz... i would recommend it only if you were using frequencies around 40+... works great tho..
Post Number: 37
alright ty alex ill check em
Username: Extrmndor3
Sit and Look pretty
Post Number: 3316
i have a spl metter the 150db version im asking 130 plus shippin its already calibrated to be close to the termal lab around1-2 db in diference really cool
Username: Sinful_systems70
Post Number: 232
You could get the Audio Controls Epic-160 because it comes with a 160 spl capable meter and microphone. Just another suggestion. Epic-160 ~ $200
Post Number: 108
allright ty, are those epis pretty accurate???
Username: Logan__tille
[:-]15 Wangers Club[:-] Premier Member
Post Number: 5051
yea, splmeter.com has some nice ones.
