Silver Member Username: Razzeldazzel06Post Number: 120 Registered: Jan-07 | im looking for the best 12 inch subs between these brands now ..i want like mostly sq and some good spl/bass for rap and techno..what sub am i better off getting...money is not an issue so what am i looking at and can u suggest what single amp would be great for any of those 12 inch subs???????? and for the fi's they say i can get it in 1 dual or two dual...which one would be better?? and the same thing goes with the id max's they say either 2 ohm or 4ohm...which setups???????? |
Silver Member Username: Razzeldazzel06Post Number: 122 Registered: Jan-07 | oh ye aand for fi subs..what is the different between the bl and the q??? they both have the same rms=1000...which on eyou think is better for daily driver who wants sq most of the time but wants to be able to bump once in a while for fun and partys and crap... |
Silver Member Username: Trey4sportsPost Number: 337 Registered: Sep-06 | ive talked to scott about this and the Q is still the higher end SQ sub, but the BL is made for a lil louder/less sq and it is really meant to be used in conjunction with upgrades and ran at higher than 1500 rms which you have stated you dont want electrical upgrades and sq so the Q is def a better match for you |
Silver Member Username: Razzeldazzel06Post Number: 123 Registered: Jan-07 | should i buy it straight from the fi website and should i get dual 1 or dual 2 and what is hte best amp for them?? |
Gold Member Username: CtmikeCt. Post Number: 3002 Registered: Feb-06 | straight from fi is the only place unless you buy a used one and what amp you use will decide whether dual 1 or 2ohm coils. |
Silver Member Username: Razzeldazzel06Post Number: 124 Registered: Jan-07 | alright so tell me what is the best amp for the 12 inch fi q's and help me with i should get the 1 dual or 2 dual?? |
Silver Member Username: Razzeldazzel06Post Number: 125 Registered: Jan-07 | anyone??? |
Gold Member Username: CenusHicksville, Ohio Post Number: 2824 Registered: Jan-05 | i'd get a idmax, amazing sub. but if you stick with the q i'd go with a sx650.1, its a very nice amp should push the q nicely. |
Gold Member Username: CtmikeCt. Post Number: 3006 Registered: Feb-06 | you can pick up a sundown saz1500.1d for $450 brand new from www.soundsolutionsaudio.com and if you do get the dual 1ohm subs. |
Gold Member Username: CtmikeCt. Post Number: 3007 Registered: Feb-06 | oops, for some reason thought you asked about the ssd. for a single q you could get a ed nine.1, kicker sx 1250, jbl 1201, arc audio kar 1000v1 (my pick), etc. any amp that'll do 800-1200wrms, clean. i'd go with a dual 2ohm q and the arc audio amp. |
Silver Member Username: LoudonPost Number: 730 Registered: Jun-04 | sx650 isnt another power for a q ... itll laugh at that power |
Silver Member Username: Razzeldazzel06Post Number: 126 Registered: Jan-07 | who thinks the id max is a better then the fi q in terms of sq and of spl.....and also for the amp how about the memphis 1100d..im looking to get two 12 inch running at lik 600 rms |
Gold Member Username: CtmikeCt. Post Number: 3011 Registered: Feb-06 | 600wrms isn't enough for a single q. i'd say it's really close on the sq, but the q might have a little more output. it'll come down to install imo. |
Silver Member Username: LoudonPost Number: 734 Registered: Jun-04 | q>idmax heard both in the same application same box same power ... q takes the cake in the everything 2.2 cu ft sealed 1000 rms |
Silver Member Username: Razzeldazzel06Post Number: 127 Registered: Jan-07 | so what should i do then with the q...i want to get two 12's...can i buy a premaid box for them in stores cause i dont want to build a box...and is it okay for me to run the q at 700rms each..1000 is going to be too much like i heard the two 12w6's and they were really loud for me isnt the q going to get like 50 times louder?? |
Silver Member Username: Razzeldazzel06Post Number: 128 Registered: Jan-07 | ???? |
Gold Member Username: CtmikeCt. Post Number: 3051 Registered: Feb-06 | if it's to much for you, try another sub or just get a single q. |
Gold Member Username: AlteraudiousaConcord Post Number: 1416 Registered: Jan-06 | i would include the SI Mag 12 if you're looking for a killer SQL type sub. Be a killer in the group. |
Silver Member Username: Razzeldazzel06Post Number: 129 Registered: Jan-07 | i dont know what a si mag is and i dont need anymore suggestions thank you..picking between id max, the w6 and the fi is extremely hard for me.....the fi i have to order off the comp i dont really trust that......and i cant hear it in person...with the id max and jl audio i have local dealers who are certified dealers of jl and i know of a store right by me that carries id max..the fi q is a great price but that doesnt even come with a dual box and i really dont wnat to go tot he hassle of findidng one that fits and stuff...i dont know too much about this stuff thats y im asking you guys and when im with a dealer they help pick stuff out for me and stuff and show me what all fits |
Silver Member Username: Livin_loud18 of Love Fi Audio Post Number: 909 Registered: Jan-06 | your best off building your box to begin. id take the Q ALL DAY over the other choices. you can order the Fi by phone. JL is overpriced. dealerships are g@y. now buy the damn Q ![]() |
Silver Member Username: Razzeldazzel06Post Number: 130 Registered: Jan-07 | i cant build a box lol i dont know how and i want it to look nice in the back of my truck i dont want it sloppy i want ti nice and clean like some machine built it...and what amp should i get for 2 12 inch q's???? |
Silver Member Username: Razzeldazzel06Post Number: 131 Registered: Jan-07 | and i want the ebst amp for those particular 12 inch q's but i aint spending over 1000 on the amp |
Silver Member Username: Trey4sportsPost Number: 352 Registered: Sep-06 | for a grand you have a TON of choices but just go out and get yourself a kicker ZX2500.1 or even two Jl 1000/1's, hell go out and have a ball with a massive audio P3000.1 1500 rms each though is REALLY pushing it i think they could take it as i have talked to someone who has done it but i wouldnt push it. |
Silver Member Username: Razzeldazzel06Post Number: 132 Registered: Jan-07 | i have a feeling these subs are to loud for me......i think im better off getting the id's or w6's...the id rms is between 200-1000 and the w6's are like 400-500..that is more my goal..if i have to pay a little bit mroe money for jl then i might as well because the id max subs are ugly as hell to look at |
Silver Member Username: Trey4sportsPost Number: 357 Registered: Sep-06 | i really think your better off with the W6 it just seems like it would fit you well, your not big into SPL you just want good clean bass and if you get 2 12w6s and a 1000/1 you dont really need any electrical upgrades |
Silver Member Username: Razzeldazzel06Post Number: 133 Registered: Jan-07 | unless i can power the two 12 inch fi's with a 1100 watt amp only giving about 600watts a piece but if that aint going to work then i dont want them..because the jl's do that and the id's do that too |
Silver Member Username: Trey4sportsPost Number: 359 Registered: Sep-06 | the Q would be fine off of that power but if you have a big budget you might wanna just go to a dealer and have this stuff done then you don't really have to worry about it |
Silver Member Username: Razzeldazzel06Post Number: 136 Registered: Jan-07 | so if i get two 12 inch q's and i go to a dealer i can get a box form them???a good amp from them??and they set everything up for me right????and ill probably need a 15 farad or 20 farad capacitor right??? |
Silver Member Username: Tremor1127Wishes there was an 18... Post Number: 728 Registered: Aug-06 | its funny how people cringe on internet forums when someone says something about running more or less than their rms rating... 2 Qs will sound great with 600rms apiece... you dont need any capacitors. with the amount of power you are talking about running your car should be fine. i would upgrade all of your power and ground wires to 1/0 though. |
Silver Member Username: Trey4sportsPost Number: 362 Registered: Sep-06 | yeah tremor is right and IF you do feel your needing a lil more voltage then get a kinetik HC1400 or even a HC800 they are much better than caps i will never recommend a cap unless its strictly cosmetics. |
Silver Member Username: Tremor1127Wishes there was an 18... Post Number: 729 Registered: Aug-06 | do you already have the 1100 watt amp? what amp is it? |
Silver Member Username: Tremor1127Wishes there was an 18... Post Number: 730 Registered: Aug-06 | i would definently get a good battery though just to feel safe, like either of those that troy said... |
Silver Member Username: Razzeldazzel06Post Number: 137 Registered: Jan-07 | memphis 1100d i heard is a very good amp...its 1100 rms x 1ohm and 600rms x 2 ohm...so should i get 2 12 inch q's with a 2 dual or 2 12 inch q's with a 1 dual..............and where can i buy a good box for them because i aint making one????? |
Silver Member Username: Razzeldazzel06Post Number: 138 Registered: Jan-07 | i want a box that is for mostly sq purposes and for good bump for rap so all around..my friends jl's are sealed and it sounds great so????????? |
Silver Member Username: Razzeldazzel06Post Number: 139 Registered: Jan-07 | can anyone answer my last two questions??????? |
Silver Member Username: WarlokOrlando, FL USA Post Number: 142 Registered: Dec-05 | I'd go 2-12's with 1 Ohm DVC. As for the box, Im a big fan of Sealed. Personally, I like the tighness of the bass and the response curve. |
Silver Member Username: Tremor1127Wishes there was an 18... Post Number: 732 Registered: Aug-06 | bobby, sent you a pm... |
