What are the advantages to quad voice coil?
Username: Impala63rag
Post Number: 338
Reffering to the digital design 99 series. Will that give the option to run 1 ohm whether it be one sub or two? Would a single voice coil be better, or just the standard dual? What are the advantages/ disadvantages?
Post Number: 341
I cant find a QVC wiring diagram anywhere.
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 1417
Quad VC are for running multiple amps and/or the ability to get lots of power by dropping the resistence.
To get a good 1500 watt amp, you will have to pay quite a bit more for one that does it at 4 ohms verses one that does it at 1 ohm.
Username: Arande2
400dB could probably d..., SouthWest Mi... Too Many DBs...
Post Number: 869
quad 1 0hm voice coil FTW!
Username: Arande2
Post Number: 870
OR, I guess it'd be useful if you were to use it in a home sub and wanted to power it using your old surround receiver, say if you got a new one?
