What gauge wire?
Username: Sk8erjim
Scottsmoor, Florida U.S.
Post Number: 94
what gauge wire will i have to use for an amp that is pushin 2 15" soundstream's at about 1000 watts rms each?
Username: N2audio
Lawrence, Ks USA
Post Number: 1137
depends on the amp you select.
4 ga is good for about 1200w. If you're actually planning to run 2000w you'll need 1/0.
you could be looking at an alternator upgrade, too.
Username: Sinful_systems70
Post Number: 229
I agree and second that! I would just go with 0 guage regaurdless becaue it isn't that expensive for big wire. Small wire could melt or couse a fire in the vehicle. Especially at 2000W RMS!! I always use big wire for safety, but mostly because I don't care about the extra cost, its not much. Just my opinion!
Post Number: 230
Sorry, it should be "Small wire could melt or cause a fire...."
