Epicenter
Username: Joebruce
U.S.A.
Post Number: 422
Well ive been reading up on these and researching them a little bit,and i think i have an idea of what they do. I am considering buying one,are they worth the money tho? Also ive been looking at the soundstream bx-12 it says its like the epicenter but its cheaper it actually looks cooler with the chrome spider lol! Are the soundstream processors any good/worth the money? Are there any other processors like the epicenter?
Www.15inchwangers.com
Post Number: 9436
get the soundstream if you want to save some money. my friend actually has that and it does pretty much the same thing. the epicenter does sound better though. or it could be that my system sounds better than my friends period.
Username: Goodie_goop
Midland, Texas U.S.
Post Number: 144
i think mtx made one awhile ago but they are hard to find but work way better then the epicenter
anyone know what im talkin about?
Username: Joebruce
U.S.A.
Post Number: 423
With my current setup ive always thought it was missing bass in some songs,mostly rock,but im hoping that maybe the epicenter will help me with that missing bass. Correct me if im wrong like i said i only have an idea of what it does im not exactlly sure.
Post Number: 9438
i listen to rock almost all the time. with the epicenter i can hear the bass guitar through the sub.
Username: Joebruce
U.S.A.
Post Number: 424
Thanks for your help chad i think im gonna get the soundstream its only 50 bucks on ebay. It will give me somethin to play around with. Any other brands i should look into before i order?
Post Number: 9439
np.
i really don't know of any other brands.
Username: J_baby15
Kentucky
Post Number: 1160
does the epicenter make a big diff. with rap?
Post Number: 9444
with rap it doesn't really. the bass seems same.
Username: Joebruce
U.S.A.
Post Number: 425
Ok there are 2 differant soundstream processors the bx-10 and bx-12. The bx-10 is $61 shipped and the bx-12 is $93 shipped on ebay.They are almost the same except for this
BX-10
THD: 0.003%
S/N Ratio: 130dB
BX-12
THD: 0.002%
S/N Ratio: 132dB
Now would the bx-12 be worth the extra $30? What exactlly is THD and s/n ratio? Would there be a big differance in them? Here are the links if you wanna check em out
http://www.soundstream.com/processors-bx12.htm
http://www.soundstream.com/processors-bx10.htm
Post Number: 9479
well if you are thinking about the bx-12 then why not spend another 40bux and get the epicenter.
Username: Joebruce
U.S.A.
Post Number: 426
I dont know i might just do that i didnt realize it was only $40 more! But what exactlly is THD and the s/n ratio?
Username: Livin_loud
18 of Love Fi Audio
Post Number: 846
don't know thd and s/n ratio, but it wouldn't really matter because audiocontrol > soundstream
18 of Love Fi Audio
Post Number: 848
found them anyways lol
thd: .003%
s/n: 130db
Username: Tacomadrifter
TAC
the epicenter makes ur bass rumble.if u ever heard one u can tell a big diff.the bass isnt just a boom, with an epicenter it gives that boom a rumble like thunder or somethin but it is somethin you would deffinatly want if you want ppl to really feel you poundin down the street.hope this helps you
