Audioque SD2.5 vs. Fi Q
Username: Mgbcs
Lincoln, Nebraska
Post Number: 95
If I were to put two 15s in a sealed box, which pair would have better SQ and which better SPL? Or is the SD2.5 more comparable to the SSD? (In that case what is better SQ/SPL between those two?) Thanks for the help.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 96
Anyone? Or is this that dumb of question
Username: Bump05
We Stay Fly, 18 SX USA
Post Number: 794
imo the sd2.5 both ways :-)
Username: Mgbcs
Lincoln, Nebraska
Post Number: 101
OK...well I guess that is good to hear then. Each SD2.5 is $130 cheaper than the Qs. Or were you stating that the SD2.5 is better all around than the SSD?
Username: Mgbcs
Lincoln, Nebraska
Post Number: 105
Any other opinions? Thanks
Username: Logan__tille
[:-]15 Wangers Club[:-] Premier Member
Post Number: 4716
lol do not put an SD2.5 in a sealed box.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 106
OK...thats why I was asking. I was told the Q would sound good in a sealed, so I just assumed the SD2.5 wouuld as well. OK, so if I put them in ported boxes, how do they compare SQ and SPL?
Post Number: 4717
the SD2.5 is more comparable to the SSD
Username: Mgbcs
Lincoln, Nebraska
Post Number: 107
OK...so the Q would obviously be better than the SD2.5. I apologize for all the questions, but what would be better SPL/SQ between the SSD and SD2.5? Thanks...I appreciate it.
Post Number: 4718
I think they are about neck and neck.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 108
OK...well the SSD takes more power and looks better so I suppose I would go with those or the Qs if I have the money. Is there any build quality differences?
Username: Mgbcs
Lincoln, Nebraska
Post Number: 109
It didn't bump...
Username: Livin_loud
18 of Love Fi Audio
Post Number: 854
i'd say both have just about even build quality... can't go wrong either way, but i'm a fi guy
Post Number: 4721
the SD2.5's can take more power.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 110
The Fi can handle 800 and the SD2.5 can handle 500???? Or am I mistaken?
Post Number: 4722
the SD2.5 can handle 1000-1200 as long as you dont clip them
Username: Mgbcs
Lincoln, Nebraska
Post Number: 111
OK...sounds good. Thanks
I am having trouble getting the info I need when I put it in the proper other forums, so I was wondering if you could help me out here. Assuming I do about 2500 RMS by the time I power two 15s and some comps, what size alt do I need? I've heard a range of 200-260. Also, what do you suggest for batteries? I've heard a Kinetik hc2400 in back with a smaller one in front, and I have heard a Red Top in front w/Yellow Top in back. Thanks for the help!
18 of Love Fi Audio
Post Number: 858
^^^^yeah, but i'm sure that would apply to Fi as well, correct?
Post Number: 4723
I would get the biggest alt i can. And i would do optima red top in the front and yellow in the back.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 112
OK...I appreciate it.
Any opinions as far as 6.5" component speakers go? I am thinking for sure no more than $350-400 for the pair. I will then pick an amp to match.
Username: Snarl2004
Post Number: 103
SD2.5. look at the HD3 though
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3530
the kinetik battery setup would be far, far superior to the red top yellow top setup. stick with kinetik.
