Power Acoustik w/soundstream
Username: Sk8erjim
Scottsmoor, Florida U.S.
Post Number: 95
what do u guys think about this Power Acoustik amp http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=485 with two of these soundstream's? http://www.shipsound.com/product_info.php?products_id=100164
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 11121
not enough power from that amp
Username: Sk8erjim
Post Number: 96
what about this one http://www.shipsound.com/product_info.php?products_id=100526
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3946
no jimbo. The cheapest amp you can get is Power acoustik a3000DB. That will give you 2000w rms nicely or pick a hifonics BXI 2006D. If you don't have enough money, then i suggest you save some cuz those subs are decent and they pound.
Username: N2audio
Lawrence, Ks USA
Post Number: 1142
That PA you linked probably isn't going to give you rated power. Plus $180's overpriced, it's available for around $140 new. Which is indicative of its real value.
IMO a legit 1000w rms would be plenty to get serious performance out of those subs, and you can find that for around $200.
Not to mention - 2000w worth of amp power is going to be quite a strain on a LOT of stock charging systems.
Username: N2audio
Lawrence, Ks USA
Post Number: 1143
a mono class D amp that will give you an acceptable amount of power at 1 ohm would be a lot more cost effective and efficient (less strain on your charging system) than the regular 2 ch amps (class a/b) you're looking at.
That's why Julio suggested the 3000db and 2006d, but if money's an issue I think you could step down to the 1000-1500w range and your subs would still impress.
The enclosure's critical too, don't forget about that.
