What is the better sub to get???
Username: Sicknt760
Apple valley, Ca Usa
alpine type X, kicker L7, or the CVX, i dont know which ones i want to get but i want to get a pair of them and i want them to be 12s
Username: Nyyfan13
Fi SSD USA
Post Number: 2148
why only kicker and alpine? theres better out there for the money
Username: Rosrock2000
FI SSD 12 , MI USA
Post Number: 50
None of em... whats ur price range.. do u want sq sql or spl? Some good sites and companys are ficaraudio.com, ascendantaudio.com, reaudio.com
Username: Sicknt760
i can spend up to 600 for the subs, i honestly dont know what sq sql or spl is but i want something that hits hard and that sounds clean at the same time
Username: Nyyfan13
Fi SSD USA
Post Number: 2154
sq - sound quality
spl - sound pressure level or somthing like that, basically loud with no sq
sql - mix of both
and is that 600 for subs and amp or just subs?
Username: Nyyfan13
Fi SSD USA
Post Number: 2155
look into
ssd or q
ficaraudio.com
2512 or 3512
ddaudio.com
sd2 or sd2.5
audioque.com
tc-1000 or tc-2000
tcsounds.com
just to name a few
Username: Sicknt760
Post Number: 7
oh ok then sql and that is 600 for just subs
Username: Nyyfan13
Fi SSD USA
Post Number: 2159
ok and why 2 subs? why not one real kickazz sub? and have you factored in electrical upgrades? once you reach about 1000-1500 rms u will need to get a bigger alt, go bigger and need batteries and alt.
Username: Sicknt760
Post Number: 8
i have factored in that stuff, i really did like how the ssd' was built and the rms really isnt all that ridiculous for them
Username: Sicknt760
Post Number: 9
but i think that i am goin to take your advice right now and order the Q's right now instead thanks dude
Username: Nyyfan13
Fi SSD USA
Post Number: 2163
yea the ssd is a very nice sub with a very nice price tag. i have one (12" with the flawind coil) and am giving it between 1000-1200rms. the ssd can take 1200 and still be fine, just gotta be careful. if u get two a kicker zx1500.1 is a good amp for them.
unfortunatly i cant tell u how it sounds because i dont have it installed
Username: Nyyfan13
Fi SSD USA
Post Number: 2164
not a problem man. the q's are very nice as well.
Username: Sicknt760
Post Number: 10
would they sound good with the zx2500.1 cause i have that now or would they sound better with the MA audio 4400w amp??
Username: Tremor1127
Post Number: 662
"ok and why 2 subs? why not one real kickazz sub?"
cuz 2 is better than 1??? 600 bucks can get you alot... anything from the list that yanks gave is good... i would go with 2 Qs, or 3 SSDs...
Username: Sicknt760
Post Number: 11
i would want to go with 3 subs but i have looked into a lot of stuff and i dont have the things to make a box and i cant find a good 3hole box that would fit my trunk
Username: Nyyfan13
Fi SSD USA
Post Number: 2166
the zx2500 would be nice for 2 q's. make sure u get two dual 2 ohm Q's tho cause that amp is 2 ohm stable.
and to be honest, i dont know anything about MAaudio amps so i cant tell you about that one.
and why not build your own box instead of buying one?
Username: Sicknt760
Post Number: 12
haha i know how to build my own box but i dont have the tools
Username: Nyyfan13
Fi SSD USA
Post Number: 2168
borrow from a friend?
and please excuse some of my dumb questions cause obviously u know what your talking about but some of the people that come on here dont know anything, and thats alrite cause i ddint when i came on. so if it sounds like im talking down to you, i dont mean it, just wanna make sure u get everything right.
Username: Carguy
Post Number: 5826
Try JL 12W7 in a HO box.
Username: Sicknt760
Post Number: 13
yeah thanks for the input yanksfan nah im not trippin man cause ive seen you in some other threads and you seem you know what your talkin about and stuff.......... its cool though cause i wanted to go out of the element of what you can go get at any bb or cc and get something different so once again thanks for the input man
Username: Nyyfan13
Fi SSD USA
Post Number: 2175
not a problem, keep us informed on what u get. everyone here loves pics.
