What do you think?
Username: Denali_on_22s
SSX, Tenneki US of A
Post Number: 799
How much of a difference in loudness would I notice if I went from 13-1400 watts to 2500 watts with my SSX?
Post Number: 800
Also... could I go with 6 cubes for my 15 or would that be ridiculous? specs say 3 cubes, but could i double it safely (just curious)
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 1349
"How much of a difference in loudness would I notice if I went from 13-1400 watts to 2500 watts with my SSX?"
https://www.ecoustics.com/electronics/forum/car-audio/308703.html
"Also... could I go with 6 cubes for my 15 or would that be ridiculous? specs say 3 cubes, but could i double it safely (just curious)"
No. Speaker boxes need to be calculated precisely and the speakers thiel parameters need to be concidered when designing a speaker box size, shape, and type.
read www.bcae1.com
Post Number: 801
that thread makes no f_ckin sense. given
Username: Tanmanfosho
C Bang, Hardcore Iowa USA
Post Number: 289
reese ur a dumb@ss u must not have read the thread close enough ill shwo the part u needed to read
Another thing;
Remember that, it takes a multiple of ten times the wattage to allow a speaker to put out twice the volume. This means that if you have an 800 watt RMS amp and you want your volume output to be twice as loud, you would need to increase your power wattage to 8000 watts RMS just to get twice the volume. If you think that you might get more volume by increasing your wattage from 800 watts RMS to 1000 watts RMS, you are wasting your time.
There is hardly a noticeable difference between an amp that is capable of pushing out (say) 5000 watts RMS, pushing out 800 watts RMS at a given time, and then you turn up the volume so that it now pushes out 1000 watts rms. Hope this makes sense.
No, I am not saying that just any 1000 watt RMS amp will not make a speaker capable of sounding louder than any other 800 watt RMS amp, since there are many other things that make an amp louder. That's why I used the 5000 watt RMS amp as an example. This way you get the same source as a comparison between the two wattage powers.
Orangevale, Ca. USA
Post Number: 1356
check this out;
http://hyperphysics.phy-astr.gsu.edu/hbase/sound/eqloud.html#c1
Our ears identify the following frequencies to be the same loudness, even though they measure differently in decibels. This is because our ears are more sensitive in the midrange than bass or highs.
According to their graph;
21 Hz - 100 dB
500 Hz - 57 dB
1300 Hz - 60 dB
4100 Hz - 51 dB
10,000 Hz - 65 dB
Also check this out;
http://hyperphysics.phy-astr.gsu.edu/hbase/sound/earsens.html#c5
Orangevale, Ca. USA
Post Number: 1358
"that thread makes no f_ckin sense. given"
http://hyperphysics.phy-astr.gsu.edu/hbase/sound/intens.html#c1
In the first box at the top of the paige under sound intensity;
"The most common approach to sound intensity measurement is to use the decibel scale:"
Thats why I use the logarirthmic example.
Username: Mygame5982
Comp Vr H-TOWN, TEXAS US
Post Number: 921
i think you'll notice a difference
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 1500
james carroll is posting a lot trying to get to gold
Post Number: 931
your sooooooooo gonna get it..
lol
jk
Post Number: 1504
I think this was the last one...are you gonna keep it up and try to go gold tonight?
Post Number: 935
naw im kind of tired of finding topics...lol
i cant get gold tonite...well i can..but you know.lol
Post Number: 1506
i stayed up until like 4am, when I went gold.
Post Number: 941
lol yea..i could go for one more hour and get it.lol
Orangevale, Ca. USA
Post Number: 1361
I only have 1300 posts. So what?
Username: Frkkevin
Post Number: 2428
.... post count is not the point of this forum.
Lol. and to answer the question. yes with more power you will notice a differenec. unless it was not a big power jump.. ex: 1000rms to 1100rms
Post Number: 819
I'm a dumbass biggs and you spelled my name wrong when it was right in front of you... anyways, no need to have animosity sorry i was drunk when i typed that
Post Number: 354
sorry i didnt look at ur name. but all u had to do was read the thread closer instead of being mean to soemone trying to help u
