Make Sealed box Ported
Username: Malizeryan
Hey. I just got a 13w7 and a 1000/1 in a sealed prowedge jl box. Its really not as loud as i thought it would be. I think a ported box would be alot louder than this sealed one, but it costed me alot of money. Could i just drill out a 4" hole in the side and it would be technically ported? would this be a bad idea?
Username: Ctmike
Ct.
Post Number: 2861
horrible idea.
Fi Audio BTL
Post Number: 8600
don't do that. besides you can't just drill a hole and be done with. you would have to stick a pipe in there. but really don't do that. build yourself a nice ported box.
Username: Skibum12189
Post Number: 28
The Prowedge was built to be a sealed design. It's too small to port. It wouldn't be too difficult to build a basic ported box for a w7
Username: Trey4sports
Post Number: 223
i dont know the specs on the box but the easiest way to "port" the box would be a circular design. go to PSP-inc.com and buy a port from there its simple and there is a calculator on there to find out wat size port u need. also you just have to cut a small hole in ur box then screw the port in, quite simple. good luck
Username: Logan__tille
[:-]15 RE XXX[:-]
Post Number: 4291
Do not do that
Username: Mygame5982
Comp Vr H-TOWN, TEXAS US
Post Number: 944
yea i agree..dont be lazy.lol
