4 Channel Amp
Username: Jeffkock
Post Number: 112
What are some reasonably priced but well working 4 Channel amps that would power 4 infinity Kappa's?
Username: Logan__tille
Orion 1200D For Sale, Hit me up
Post Number: 4046
Username: James1115
Use a simple...
Post Number: 8595
rms?
Username: Kellogs211
The yamaha A460 Should
Username: James1115
Use a simple...
Post Number: 8619
how can you reccomend a amp Jonathan without knowing the size or rms power of the speaker?
Username: Jeffkock
Post Number: 113
90 Watts RMS Each
Username: Jeffkock
Post Number: 114
at 2 ohms
Username: Ctmike
Ct.
Post Number: 2855
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=470
Username: Tjmutlow
Post Number: 3440
i have an ARC audio kar-400.4 like new for $175 delivered to most areas
Username: Smittty
Silvis
alpine mrp-f306 i have one and wouldent get rid of it 4 nothing their cheap 2
Username: Qbenjamin
Florida
Post Number: 179
ty, do you still have that Arc amp for sale?
Username: Qbenjamin
Florida
Post Number: 180
Never mind, I didn't know that it was only 50 X 4 @ 4 ohms
Username: Tjmutlow
Post Number: 3452
if those are the new kappas, those are 2 ohm speakers and that amp is 100x4 at 2 ohm plenty of power for them.
Username: Jeffkock
Post Number: 116
i am getting 2 pairs
Username: James1115
Use a simple...
Post Number: 8718
I have a kicker kx 700.5 that I will sell you. It will push those kappa's fantastic and also push a sub. It has a 4 chan class a/b amp and a class D mono amp all in one case. the best of both worlds.
Username: Tjmutlow
Post Number: 3453
and getting 2 pairs you run a speaker to each channel at 2 ohms running 100w,
