Thursday, May 06, 2004 - 03:08 GMT guy i just bought my second sub they are both dual 2 ohms. now i had the one briged to 4ohms, and i just wont to make sure that if i briged the second sub to 4ohms it will give me a 2ohm load to my 2ohm stable mono amp.
Username: Vipersbyms Post Number: 102 Registered: Apr-04
Thursday, May 06, 2004 - 04:11 GMT you bridge amps, not subwoofers. what you are doing is wiring the subs in series. yes wiring two 2 ohm DVC subs in series will give you a 2 ohm load to a mono amp.
Friday, May 07, 2004 - 01:13 GMT bridjing is when you take something to connect one item to another item yes it can be called bridjing as well kevin
Yeah I said It
Friday, May 07, 2004 - 09:15 GMT Bridging not Brijing, hahaha.
Yeah I said It
Friday, May 07, 2004 - 09:15 GMT bridjing, lol
Ryan98192
Thursday, May 13, 2004 - 22:08 GMT If i wire two 4ohm Subs in a series will that give me a 1ohm load? And is it possible to wire two 2ohm subs to get a 1ohm load?
