A\D\S components kenwood amp..
Username: Johnfiac
IL Afghanistan,...
Post Number: 891
Ok i have a set of A\D\S 346cs i think the model is and a set of 5way pioneer 6x9's on a 2ch. kenwood amp i have each pair wired to a 2ohm load and placed them on seperate channels and it sounds good but i am not sure if i set the gain correctly the amp should do about 250rms @2ohm per channel so i am just about maxing the speakers out but thats not my problem... when setting an amp for mids\high's what test tone is best? I used 2000hz is that right? And on another note, the fuses in my drossover networks glow red when the amp pushs more power out is that normal for this to happen? They do it fairly easy and still sound clean when it happens it isnt even really loud at all when they arent lighting up i mean they are but not much.. they take about 25rms anything over they pretty much light up glowing red. is that fine?
