Dual 1 OHM or Dual 2 OHM
Username: Tanmanfosho
C Bang, Hardcore Iowa USA
Post Number: 292
FI SSD 12inch. should i get Dual 1 OHM or Dual 2 OHM? ran off a hifonics 1206D.
Username: Bernymac
Cambodian
Post Number: 1677
how many subs are you getting?
Post Number: 293
1 and now im nto sure if i want a 12 inch or a 15 inch
Username: Frkkevin
Post Number: 2406
for that amp.. dvc 2 ohm
Username: Mygame5982
Comp Vr H-TOWN, TEXAS US
Post Number: 900
agree^^
Username: Frkkevin
Post Number: 2443
but the comment on wire was quite funny.. although it would increase the resistance. not lower it :-)
Username: Cashkid
you want to use 2ohms as this will prolong the life of your amplifier and speakers
Username: Frkkevin
Post Number: 2448
....DVC 2 ohm subs wire down to 1 ohm or up to 4 ohm
if the amp is 1 ohm stable wiring it to 2 won't make it last any longer than 1 unless it was just a horrible amp to begin with then it would not last long on either
