Parallel Or Series?
Username: Ars88
Rotti Pit , Corpo...
Post Number: 228
got a kicker 750.1 amp thats stable at 2 ohm...now i have a kicker l7 which should be dual 4 ohm
my friend did a parallel or a series wiring (not sure yet which 1 coz i didnt open up sub to see) but i need to know which wiring method would be the correct one for my amp to stay stable...would either of those methods work?
i just figured out why my amp would go on protection mode so maybe this could be the reason
i need to know which wiring method would be the correct method so my kicker 750.1 would be stable at 2 ohms..
thanks in advance
Username: The_image_dynamic
San Diego
Post Number: 74
Parallel to make it 2 ohms. Series would make it 8 ohms.
Username: Frkkevin
Post Number: 2307
^^ parallel
