Sealed/ported
Username: Nickyp0219
Post Number: 118
hey guys, ive had my setup for a few months now, and im pretty pleased..i want somethin more tho and i think its my box. i originally wanted ported, but got talked into sealed. I have a kicker l7 sealed 15" in a 01 eclipse. i had to get a custom sealed enclosure to fit in there. you think it would make the diff. gettin a ported box?? thnx
Username: Nyyfan13
Fi SSD USA
Post Number: 1885
in theory, ported tends to be 3 dbs louder than sealed, in theory tho. ported shuold make it louder tho. give it a try and see how it goes.
Post Number: 119
would it sound muddy in an eclipse tho? could i expect to hear a big diff?
Username: Logan__tille
RE XXXYeah its 15 ...
Post Number: 3686
NO. It will prolly sound better..
Post Number: 120
anyone know where i can find a site to help me build a custom ported box for this?
Username: Suleman36
Post Number: 4151
ok first, you need to determine what the speakers are made for.. not all drivers work in both box types.
you need the TS stats 9should come with the subs, or download the tech specs from their website)
and calculate the EBP
here's how:
Efficiency Bandwidth Product (EBP)
EBP = Fs / Qes
50 or less = best used in a sealed enclosure.
50 - 90 = flexible enclosure options.
90 or greater = best used in ported enclosure.
very simple calculation.
Username: Nyyfan13
Fi SSD USA
Post Number: 1918
this site right here
use this thread or make a new thread abuot your sub, size, room yuo have, ported or sealed.
people will help, if not, then someone will give yuo a site
Post Number: 121
alright this is what i got on the sub..hope this is what u need.
Resonance Frequency = 26.3
power handling = 2000max, 1000rms
Total Q Factor = .507
Equivalent volume (Vas) , ft^3(L) = 5.2 (148.6)
Outer Frame dimension, in (cm) = 15 5/8 (39.7)
mounting depth, in (cm) = 8 1/2 (21.6)
I have it setup with a memphis pr 1000.1 amp in a 01 eclipse hatch, so space is a problem. the enclosure i have now is sealed and the sub is faced upwards due to space restrictions. please let me know the best way to build a box w/ a port w/ enough room, thanks a ton guys
Post Number: 122
anythin else just lemme know
Username: Nyyfan13
Fi SSD USA
Post Number: 1927
ported correct?
and its a 15" L7?
Post Number: 123
right
Username: Nyyfan13
Fi SSD USA
Post Number: 1928
ok, just wanted to clarify that for people reading it. im no pro at making boxes. if i oculd help yuo, i would. but i cant.
someone will read it tho and help yuo and if no one does, then make a new thread.
