A few question about the Q
Username: Nkknutson
Fist i'm a rookie what does "spl id" mean? and if i buy a Q or the SSD how many do i need is one enough our do i need two, i was thinking 12"? I love to listen to rap and so i don't need that quick response that rock needs "right"? and is there any other good subs for around $400 total price for rap. If i do buy the Q or the SSD any good amp ideas for them?
Username: Logan__tille
RE XXXYeah its 15 ...
Post Number: 3528
Sound pressure level, loudness-(spl). And, you have to figure out what your going to buy first....the Q....or the SSD.
Username: Nkknutson
If i buy the Q i can only aford one but if i get the SSD i will get two. both 12" are these subs good for rap?
Username: Nyyfan13
Fi SSD USA
Post Number: 1691
yea figure out which one you want.
but anyway, a good amp for a dual 1 ohm ssd could be the kicker zx750.1. wire the usb to 2 ohms, amp is 2 ohm stable
for the q, kicker zx1000.1. dual 1 ohm Q, wire to 2 ohm, amp is 2 ohm stable
just to name one amp for each, many others tho
Username: Nyyfan13
Fi SSD USA
Post Number: 1692
yea both are fine, even with one. the q will get loud and stay clean, sql. and the ssd will do the same, but i think is more to the spl side compared to the q but still would be considered a sql sub.
