CANAAN...or anyone else really...
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 1339
this is mainly for Canan.....I'm going to see about buying some subs from him...RE 8's. They're 175 watts rms each..now, I can get a kicker zx350.2 for about $200 shipped.
1>since it is 175rmsx2@2ohms shouldn't that work perfectly with those subs?
2>since the subs are dvc 4ohm...to hook each one up, I hook the + on one vc to the + on one channel, and the - on the vd to the - on the other channel, then do the same thing on the other sub on the second channel...correct?
btw, heres a pic of the amp
Post Number: 1340
whoops I misspoke,. I meant hook the + on one vc to the + of one channel and the - of the other vc to the - of the SAME channel, then hookup the other amp the same way on the second channel}
Post Number: 1341
grr still said it wrong, I meant hook up the other SUB the same way
Username: Mygame5982
Comp Vr H-TOWN, TEXAS US
Post Number: 870
hell no......thats wayyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy yyyyyyyyyyyyyyyyyyy too much for that lil ole amp..never dude farealz.lol
Post Number: 1345
TOO much for the amp??? the amp says its 175watts rms x 2channels at 2ohms...and the subs are 175 watts rms each, so if I hookup 1 sub to each channel shouldnt that work?? If not...let me know a good amp then.
Username: Bump05
We Stay Fly, 18 SX USA
Post Number: 562
prob be a lil more then u think..
350x2 is a lil to much
try something more like 170-200 x 2 and ull be fine
and if there dualvc hook them up 4 ohm loads
svc hook them up 4 ohm loads
EASy....
Post Number: 1348
its not 350x2...its 175x2...heck just give me a better amp for the same money if u can
Post Number: 1349
or maybe a mono amp would work better, but I need to find one that i can hook up 2-dvc-4ohm subs correctly
Post Number: 1351
see....http://www.techronics.com/index.cfm?fuseaction=product.display&product_id=3749&g clid=CKCI87XmmokCFQ0wUAod0EuIPQ
Post Number: 1352
and I can get it there for about 170 shipped....so IF I wire each sub to a separate channel, then it should be ok...or am I missing something?I mean if each channel is separate like that and I wire each sub to 2ohms...doesnt that mean each sub is going to get 175 watts?
Post Number: 1353
whoops accidental double post
Post Number: 1354
http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/car/subwoofers_du al.html
wire them like it says to wire a stereo amp under the parallel section..right??
Username: Waterboy2289
Martinez, Georgia USA
Post Number: 149
yes you will be fine with that amp and those subs
but if it were me i would go for a cheaper amp.....beacuse you can get 350w rms alot cheaper than that
Username: Bump05
Post Number: 570
Ok i see...and yes the amp will be fine for those subs ^^ dunno what he was talking about... also if the subs are dual 2 ohm subs hook up like this http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =2&impedance=DVC2x2 or if there dual 4 which i dont think they are hook them up like thishttp://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =2&impedance=DVC4x2
and just bridge them to the kicker amp... which will be putting 35o maybe lil more to both subs and you will be set
Post Number: 1355
Canaan said they were DVC 4's...and thats what they say on the specs on RE
Post Number: 1356
ok so I would wire them up like this...right?
and hook them up to the amp so that is MONO....correct?? the amp is 350wattsx1@4ohms..so if I hooked them up like shown above, that would be 175watts each...correct?
Post Number: 151
You CAN get 350w rms cheaper....if you are going to buy unautherized then atleast get the best deal possible
Post Number: 1357
here's the subs...look under the RE series ...8" subs....175 watts DVC...see
http://www.reaudio.com/specs.html#sp_re
Post Number: 1358
left out part of that DVC, 4ohm
Username: Bump05
Post Number: 572
yeah wolfman perfect :-) the diagram u posted which i showed u will work perfect for the subs and amp cant get any better and y go for cheaper the amp is already cheap plus qualtiy...just do what u were going to do wolfman now ur set
Post Number: 152
an amp like this rockford fosgate 400w
http://cgi.ebay.com/ROCKFORD-FOSGATE-P4002-PUNCH-2CH-400W-AMPLIFIER-AMP-NEW_W0QQ itemZ120064021937QQihZ002QQcategoryZ39737QQrdZ1QQcmdZViewItem
is only 137 shipped and you can purchase a full 3 year warranty on it for $20, plus millionbuy is much more reputable than techtronics
Post Number: 153
ebay item number: 120064021937
Post Number: 1359
cant use ebay. thats why
Post Number: 1360
now, i just hope I get the money for Christmas, I think i'll get enough for the subs, but I may have to save for the amp.
Post Number: 157
http://www.bargainunlimited.com/servlet/Detail?no=55
Post Number: 158
http://www.ikesound-car-audio.com/rec/2922-Rockford-Fosgate-P4002
Username: Bump05
Post Number: 578
id still go kicker imo. those punch amps werent all that great. if i went rockford id go older or there top line.
Post Number: 1361
thanks anyway matt, but I think I am gonna stay with the Kicker
Username: Adddisorder
West palm, Florida
Post Number: 2390
or pgx400.1 you can pick them up for cheap. and it would work fine with the subs if not the kicker will work
