Which DVD player should I get? Jensen or Dual?
Username: Snowboardbum
I was wondering if you guys could help me decide on which dvd player to get. I've been looking at the Jensen VM9311TS and Dual XDVD8181. Which one would u get?
Username: Tjmutlow
Post Number: 3351
neither, but Jensen if you have to take the lesser of the 2 evils.....
why are they evil... they're both good cheap dvd players, some people just don't know how to use them.
Username: Sammazda3
Jensen VM9311TS
play really well good resolution well equiped REALLY GOOD SOUND
And it's really cheap
could anyone take some pictures of the main menu and the menu for music plz?? Im just worried that its not fully touch screen like the dual is. And also the fact dual shows the fast forward and reverse buttons on the unit while jensen doesn't.
Fi AudioBTL
Post Number: 7844
they are both garbage man. the sq on those things are so awful. you are better off just getting a regular hu.
spend some $$$$ and get a pioneer avhp-7500dvd. this unit has awesome sq.
I have plenty of stuff to have good sound in my car, no worries about that, but just cuz they're not top notch and $1,000 dollars don't mean they're garbage. But w/e.
Username: Tjmutlow
Post Number: 3352
the panasonic is not 1000 and is a much better unit then those, they are only around 550
Post Number: 7
o really? that sounds better, where could i find that unit?
Post Number: 8
okay, I found a very nice sleek looking panasonic unit. The model is Panasonic CQ-VD7003U. How would that one be?
