How to set the gain??
Username: Bump05
18Sx, UsA USA
Post Number: 324
Alright how do i set the gain on my amp correctly? does it really matter will u notice in your bass if it hits less? i got a rockford 800aII, oh and on my hu it has front and back rca's and one cord thats blue that says subwoofer which one do i connect to for my sub, i would thikn the sub but it only has one outlet not two and its blue lol
Username: Livin_loud
8======D , 18 of love Fi Audio
Post Number: 604
you need a Y adapter for your sub output
Username: Bump05
18Sx, UsA USA
Post Number: 325
will that throw more voltage the the rear and front rcs outputs?
Post Number: 607
why would it matter? lol, you use the subwoofer output for the subwoofer. using the other ones would give your sub amp a mid/high signal
Username: Frkkevin
Post Number: 1829
use the subwoofer out RCA .. turn your h/u to 3/4 volume.. select a note 8-10hz higher than your boxes tuning frequency and get your DMM ready.
now take the RMS power you are running and multiply it by the OHM load it is at. now once you get that answer take the square root of your answer.. that is the voltage you are looking for.
put the DMM on the output for your subs and turn it to 200AC or similar .. play the tone and turn the gain higher or lower until you match the voltage you caculated.. assuming you do not know box rise i'd set the gain a tad higher in voltage due to the imp rise
Username: Skies
Courtenay, British Colu... Canada
Post Number: 350
from that calculation i get 34.6V.... doesnt seem right ?
Username: Redliner
Wilmington, Ma
Post Number: 3247
or u could just go online lol find out the output voltage ur hu does, then just match the gain on ur amp and where u think it will match turn it down a bit lol the normal way to do it
Fi AudioBTL
Post Number: 7462
good point charlie and kevin has.
set the gain correctly you must.
Username: Frkkevin
Post Number: 1833
that seems fine.. mine is set at 50v
Username: Skies
Post Number: 351
"good point charlie and kevin has.
set the gain correctly you must."
the force is definitely strong with this one..
Fi AudioBTL
Post Number: 7464
http://www.subwoofertools.com/forum/setgain.asp
Username: Rvlacos
DD 3512 United States
Post Number: 987
more proof we need stickys
