Headliner
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1545
Any tips on taking a headliner out of an SUV? I think in in way over my head...no pun intended. I have a 03 mercury mountaineer AKA explorer. thanks guys.
Username: Nd4spd18
Post Number: 105
Once you take you off all the interior trim the headliner should just fall down, but be careful they are easy to break. I removed mine myself when I had it re-covered, I just pulled it straight out the back. But it would have been easier if I had someone to help me.
