So im tryin to setup my system
Username: Ndjumpman23mj
Post Number: 21
my first system and im having trouble choosing an amp kit..i have 2 12 inch subwoofers powered by 2 audiobhan 800 rms each.
rite now im considering buying this:
http://www.cardomain.com/item/ROCCP4CKDS
i kno i need more stuff such as a capacitor and a distro block, any websites where i can find a good selection? any suggestions? also PLEASE give me a good suggestion on a capacitor!!!
thanks
Username: Dustin3
Tigard, OR U.S.
Post Number: 4272
do you have 2 a800v's? one on each sub?
so since you have a total of around 1450-1500 watts, i would get a big 1/0 wire, ran from the battery to a istrobution blcok, then out into 2 4 awg wires that go into each amplfier. or else, you would have to get 2 of those amp kits ^^ that you posted.
DONT GET A CAPACITOR! unless, you have a really great charging system...
read this:
http://www.wickedcases.com/caraudio/capacitors.html
Caps are wayyyy overrated and only (if you have enough juice to support them) will smooth out the voltage rails basically.
as far as good wires and selection, www.knukonceptz.com are realy nice.. and then there are tons of other cables that are nice also. kicker and RF and JL make good wires too. same with street wires
monster wires are great also:
http://www.monstercables.com/mpc/product_pages/200_power.asp?section=two
chek out their distro blocks, and wires :-)
Post Number: 22
so would this amp kit be good enough for my system?
http://www.knukonceptz.com/productDetail.cfm?prodID=KLM-AK0
and which of these distrobution blocks do u reccomend?
http://www.knukonceptz.com/productMaster.cfm?Category=Distribution%20/%20Fuse%20 Blocks
Post Number: 23
Post Number: 24
Username: Dustin3
Tigard, OR U.S.
Post Number: 4327
ok, so are you gonna be running an amp on each sub? and what amp is it?
Post Number: 25
yea im gonna run an amp to each sub, and they're audiobahn A8000V
Username: Dustin3
Tigard, OR U.S.
Post Number: 4329
ok. so i would get X amount of 1/0 power wire, then i would get 2 4 awg amps kits off knukoneptz (or somewhere else, and then a distro block that has 1/0 input and 2 4 awg outputs.
a distro block it really doesnt matter what kind, any one from knukoneptz is fine, just has to be 1/0 input and 2 4 awg output
Post Number: 26
so X amount of this wire is what i need?
http://www.knukonceptz.com/productDetail.cfm?prodID=KLM0BL
Post Number: 29
Username: Dustin3
Tigard, OR U.S.
Post Number: 4338
yep.
Post Number: 30
Username: Dustin3
Tigard, OR U.S.
Post Number: 4347
i said yes...............
Post Number: 31
my bad my sidekick is messed up..thanks for all your help i greatly appreciate it
