High Output Alternator
Username: Cplaya280
Quakertown, PA USA
Post Number: 333
Where can I get a decent price high output alternator for a 2002 chevy impala, and what alternator amp output is good for this setup I deff need a new one because my lights dim really really really bad im afraid one of these times the car is just gonna shut off lol. I'm running 2 12" kicker l7's with a kicker zx1500.1 amp. so any suggestions or help thanks
Username: Ctmike
Ct.
Post Number: 2503
http://stores.ebay.com/Iraggi-Alternator-and-Electronics
http://www.excessiveamperage.com/
Username: Logan__tille
HD3, Www.Audioque... United States
Post Number: 2564
Username: Cplaya280
Quakertown, PA USA
Post Number: 334
ok which alternator amp would I be safe with getting using a 2 12" l7 and a zx1500.1 amp. and idk what it means but alt amp and alt amp idle.
Username: Ctmike
Ct.
Post Number: 2504
is that the only amp your running? if you can afford to get the biggest you can find for your car. even if you don't need the extra power now it never hurts. but i would go at least 200a.
Username: Andrew571
Post Number: 262
do iraggi, better prices
Username: Cplaya280
Quakertown, PA USA
Post Number: 335
yeah a zx1500.1 so its benched at 1769 watts and my lights dim like crazy so i nkow i need a new alternator so ur saying go at least 200 and i should be fine no dimming or anything then??
Username: Stnorris
Davenport, IA US
Post Number: 1712
ya a 200 would work nice. go irragi...cheaper prices for a better/more powerful alternator
Username: Ctmike
Ct.
Post Number: 2506
ho alt. doesn't mean it'll stop all dimming, but yeah you need one. just remember get the biggest you can, do the big 3, and replace the battery if you haven't already. an extra wouldn't.
Username: Cplaya280
Quakertown, PA USA
Post Number: 336
would this one work nice with my setup and stop most dimming or all dimming http://cgi.ebay.com/ebaymotors/220amp-Iraggi-Alternator-99-00-01-Chevy-Buick_W0Q QcmdZViewItemQQcategoryZ33573QQihZ019QQitemZ7958419364
and what does it mean by amp idle?
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 770
I always thought Iraggi was expensive?I paid $535 for my 300 Amp Alt from Iraggi.Oh and also...alts from EA have lots of problems I'm not sure why people reccomend them.In my opinion Excessive Amperage Alts are crap :-(
Username: Andrew571
Post Number: 263
idle amps are the amps the alternator will produce when ur car is idle... like at a stop light etc.
Username: Cplaya280
Quakertown, PA USA
Post Number: 337
oh alright so would 100amp at idle be alright then cuz its 220Amp and 100 Amp Idle so would this be good for my setup
Username: Andrew571
Post Number: 267
yes
