Any thing i should do different on this...
Username: •cam•
Post Number: 15
So I figured out what i'm gonna get and measured the spot behind the back seat in my little tracker.
-1 Assassin 12
-The PPI AX606.2
-Panasonic MXE CQ-C7203U from Crutchfield for the head unit http://www.crutchfield.com/cgi-bin/ProdView.asp?g=300&tab=features _and_specs&i=133C7203
-Maybe these MB quarts
http://www.cardomain.com/item/MBQDKF116
Now onto the enclosure.
Here's the WinISD file:
http://www.filefactory.com/file/4fe814/
If you don't have WinISD the box will be 2.8cuft without the port or bracing or anything. I just need to figure out how much the bracing and the port will take away from the volume. When they say 2.0 cu ft on the AA site do they mean 2 cu ft without the sub in there or 2.0 cu ft + whatever the sub takes up? I guessed it would take up .8 cu ft but this is my first box and my first install so i have no idea. Anyway could you check that out n let me know if I screwed up.
heres a picture of it in winisd
imageshack .us/img122/8131/winisdboxel4.png
Username: •cam•
Post Number: 16
bump
Username: Logan__tille
HD3, Www.Audioque... United States
Post Number: 2521
Is your tracker a 4 door?
Username: Adddisorder
West palm, Florida
Post Number: 1886
get a dif. HU probly a pioneer
and you using that PPI amp for sub or for the MBs
Username: •cam•
Post Number: 17
nah two. its a '96 soft top. pics are comin. im gonna cut a hole in the middle of the back seat for the sub. amp is for both its 6 channel
http://www.usedvictoria.com/classified-ad/2150676&category=car-audio
yeah i'll look for another h/u but whats wrong with that one?
Post Number: 2526
panasonics not that good...i would get this one...
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3499
Username: •cam•
Post Number: 18
heres some pics. http://profile.imageshack.us/user/camrennie/images/
West palm, Florida
Post Number: 1889
yup, ^^that one is nice though
Post Number: 2527
I have a little tracker like that....but mines white.lol
Username: •cam•
Post Number: 19
nice. yeah i dont have a license cuz im 14, but my dads got 10 acres so this guy he works with gave it to us for 50$. he's just gonna use it sometimes for camping. anyway im on a budget so i'll probably go with this hu.
http://www.crutchfield.com/cgi-bin/ProdView.asp?g=300&tab=features _and_specs&i=130DEHP380&cc=07
Username: •cam•
Post Number: 20
but yeah how does the box look?
Post Number: 2529
What about this?
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3497
Thats whats in my tracker
Post Number: 2530
Whats the box tuned too? You wont need to brace that box. The port will do enough bracing.
Username: •cam•
Post Number: 21
check the pic that'll tell you most of it. im not exactly sure what im doin with this so thats why posted it. but to stop any spikes in the graph on winisd i tuned it to 20hz.
Username: •cam•
Post Number: 22
how will the port brace it? im using a circular port.
Username: •cam•
Post Number: 23
o sh_t the ports gotta be 1m to stop it from whistlin on this box. what a b_tch.
Username: •cam•
Post Number: 24
anyone know the displacement of an assassin 12. i checked the site but i couldnt find it.
West palm, Florida
Post Number: 1891
its like .2 ish
its pointless to tune that low IMO it would be easyer to just seal it up.
and that last link logan posted is a good buy. but that one you posted isnt bad
Username: •cam•
Post Number: 25
well if its .2 then ima guess the port will be .1. so thats 2.5 instead of 2 like i had so one sec.
West palm, Florida
Post Number: 1894
ok the ports displacement is more then .2
first figure out how big you want the sub to be in, id choose 2cubes plus port.
if your doing aero port i would get flared ends from partsexpress.com and use 4" pipe
then if you go that route instead of slot port determine the displacement of the aero port by 3.14r^2 i think.
subwoofertools.com and winisd are your friend
Username: Teamdeboy1971
OPTIDRIVE LN., TN Major Bass P...
Post Number: 136
hEY, What are the specs on the box in the picture? I am looking for a setup sorta like the one pictured! Tuned to 40hz or tuned to something that is spl worthy!!
Username: Andrew571
Post Number: 230
LOL logan, i knew it was about time u post that pic again. what is that? 20th lol jk with ya mang
Username: •cam•
Post Number: 27
alright well im just gonna put 1 slot port firing under the seat.
the port will be 40.75" wide and 3" tall and 10.81" deep.
