Sealed vs. Ported...the debate goes on...
Username: Pitbullguy
Chi Town
Post Number: 91
Still haven't decided which way to go. How much SQ would i sacrifice by going ported? How much power would i sacrifice by going sealed?
2 12" assassins in a sealed trunk.
Username: J_baby15
Kentucky
Post Number: 849
Not alot of SQ if you tune low. maybe 32-33. What amt. of space do they need for sealed/ported?
Username: Adddisorder
West palm, Florida
Post Number: 1888
personally i love SQ and would never port one. i had mine in 1.4sealed.
you could do like 2cube each tuned to 28hz personally i wouldnt tune higher
Chi Town
Post Number: 93
someone was trying to tell me that if i go sealed...it like wont even be heard outside the car...like the bass won't carry at all...false?
link to specs...think it says 1.2cuft sealed...2.0cuft ported.
http://www.ascendantaudio.com/assassin12specs.html
Username: J_baby15
Kentucky
Post Number: 852
It'll be heard outside...just not as much. Ported moves ALOT more air. Ported is not going to make it sound bad. Ported will also make it much louder.
Username: J_baby15
Kentucky
Post Number: 854
crownvic do u got AIM or MSN?
West palm, Florida
Post Number: 1893
yeah its false. ported will be louder. i had an assassin 12 and you could hear it outside the car no problem. especially with the windows down.
if you are looking for loud port it. should still maintain decent SQ
Username: Suleman36
Post Number: 4124
I have a 99 Crown Vic and have run ported and sealed. Ported will be louder overall but sealed usually will give you better Sound Quality and flatter frequency response. I personally prefer sealed but it depends on the subwoofer aswell.
I have a 12w6v2 in a sealed box off a JL 500/1 amp and it sounds real good.
Chi Town
Post Number: 94
i also had someone tell me that i should put some nice speakers in front, and leave the rear speaker compartments empty for the sake of extra air flow... is that a good idea? does it depend on whether i go ported or sealed?
Chi Town
Post Number: 96
yeah i got msn windows live messenger thingy jordan.
pitbullwrangler
Username: Redliner
Wilmington, Ma
Post Number: 3021
most likely the ported will be about 3 db's louder than the sealed which u will be able to tell by ear but its not a huge diffrence either
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3407
that's the rearfill theory.
read this www.wickedcases.com
Chi Town
Post Number: 97
nothing to read w/ that link :-(
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 1190
Why not build a sealed box and a ported box and see for yourself. Then you will know which one "you" like. Asking other people which is better, is not going to satisfy you at all.
BTW SQ is subjective, and you dont lose power by going sealed. You lose volume. Going sealed allows you to play your subs at its full RMS without bottoming out. POrted will be louder, but it will not take full RMS because it will bottom out faster due the the lower air pressure inside the box.
Hope this makes sense.:-)
Chi Town
Post Number: 98
thanks for the info, it helps. but what do you mean by "bottoming out" ?
Username: Basshead86
OG eCoustics Member
Post Number: 8808
when the VC hits the top and bottom plate, essentially running out of forward and back movement room.
too much power, too big of a box, playing below tuning. etc....
