Subs louder than two 15" L7's
Username: Bernymac
AQ HD3!!, CA United States
Post Number: 996
A guy at my work said he can get two L7 15's for 250 a piece. I told him I might be able to find it for lower, but I wasn't able so far, unless someone knows a site that does? Thats including shipping.
But on to the main thing, I told him also that I can find him subwoofers that are better, and louder. So why don't you guys throw me some subwoofers because I'm unsure what subwoofer can compare to a L7 in loudness. Since I haven't heard both and all that. I think 500 is his budget, warranty is a plus.
I think I gave all the information needed to ask for your help, I'll be sleeping all day since I work graveyard and I'll be back on at 6:30PM tomarrow Pacific time. Thanks guys. Oh yeah, I'm almost gold =). Horray for me, meh..
Username: Bernymac
Post Number: 997
btw, he wants 2 15's.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3395
1 BTL fully loaded with 6000w rms
Username: 54danny54
Betsy layne, Kentucky..GO... \blink, red,...
Post Number: 2909
tell him to use a single havoc with round 2k-2.5k watts
Username: Livin_loud
Ny
Post Number: 467
Hey, if he wants to stick with those L7's and he doesn't mind them a little used... let me know lol
Username: B101
DD, RE, FI, TREO, KICKERUSA
Post Number: 3920
2 15" SSXs will get louder with enuff power...
its really hard to compare to a L7, cause those subs do move alot of air beein a square...
I dont think 1 BTL fully loaded with 6krms will outpower 2 L7s with 6krms totall... lol
2 BTLs will be better! :-)
Hifonics also has some square subs also.... look into those..
Username: Logan__tille
HD3, Www.Audioque... United States
Post Number: 2519
2 Audioque 15 inch HD3s
Username: Bernymac
Post Number: 999
His budget was 250 per woofer. Can you think of anything at 250 per woofer that can out do a L715 in loudness? I was thinking about a FI Q, but I'm not sure.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 10243
no subs in that budget will be louder...with the same amount of power...period...
Username: Bernymac
Post Number: 1000
Yeah thats what I thought. Well I guess its L7 for him then. Thanks for the input.
Username: Teamdeboy1971
OPTIDRIVE LN., TN Major Bass P...
Post Number: 137
Loud as in bass you can feel, or loud as bass that sounds like a giant tweeter? SQ OR SPL?
Username: Bernymac
Post Number: 1003
spl, and I had a feeling inside that at 250 per woofer for a 15" L7, you can't find anything really that can get louder. And if you did, you would have to pay a lot more to be louder and more clean. I'll check with the guy to see if he wants some sound quality or if he just wants to be loud, if he wants some sound quality I'll recommend him the fiQ. But he was interested in the L7 thats why I said spl so I was trying to look for something that can be as loud and clean or just louder at around the same price range.
Username: Rvlacos
DD 3512 United States
Post Number: 448
they are cheap and loud as hell
