Box carpet?
Username: Tweeker
RE AUDIO
Post Number: 570
were do you guys get your box carpet from? not online please. they tried to charge me 12.50 a yard at the swapmeet. does walmart have any?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3258
idk, try asking lol. a car audio shop will have it and upholstery shops can get it.
Username: Tweeker
RE AUDIO
Post Number: 571
how much should i expect to pay? d@m carpet cost as much as the mdf.
Post Number: 3262
i dont know I've always vinyled stuff. the vinyl im going to use for my box is 20$ per yard. not cheap at all, but its the best out there... you get what you pay for.
Username: Stnorris
Davenport, IA US
Post Number: 1573
walmart has some stuff in the auto section of the store. you could prolly go to a local car audio shop too, or target, best buy, w.e.
Username: Adddisorder
West palm, Florida
Post Number: 1790
homedepot./lowes just any indoor outdoor carpet
Username: Fi_car_audio
Hades, NV
Post Number: 41
Its always nicer if you can find the unbacked stuff. It is also refered to as "trunk liner". The unbacked carpet srtetches and conforms to curves and angles MUCH easier.
Call an upholstery supply place and see if they have "trunk liner". If they do, then they might also have the better version of unbacked auto carpet as well. Dont be shy with the spray adhesive either ;)
Username: Frkkevin
Post Number: 1626
eBay.
Username: Kaos15th
Post Number: 283
^^^"not online please."
Username: Tdawg30
Ohio USA
Post Number: 515
use fleece. may not seem like the top choice but thats what I use and it stretches nicely and if you use spray adhesive everything stays nice and flat and looks really good.
Username: Tweeker
RE AUDIO
Post Number: 572
i ended up getting a 40inches by 20ft roll for 15 bucks. thanks guys
