Help?
Username: Thakidgame
Hialeah Gardens, Florida U.S.A.
Hey, Im new to Car Audio... Yesterday I went to Brandsmart U.S.A. looking for some subs. I stumbled upon the JBL gt4-12 subs. I saw 1000 Watts.. Im like wow.. that must bump hard..
Now I returned to brandsmart today to look for the cables I need to install the subs, and I asked what cables do i need? The dude asked me how big is the amp and which subs? Im like those subs.. and I want to buy like a 2000 watt 2-way amp.. since what I thought was 2000/2= 1000 watt for each sub.
He told me each sub had 250 R.M.S. , this is what I don't understand. What is R.M.S. and what is the total watt I could go with it? Can someone explain how this works.. and which is the best amp (Meaning loudest without blowing them) that would go with these subs?
Here are the specs.. Just in case
* 12" 1000W peak subwoofer
* Power Handling, RMS: 250 Watts
* Power Handling, Peak: 1000 Watts
* Frequency Response (±3dB): 28Hz - 450Hz
* Sensitivity: 93dB
* Mounting Depth: 6-1/4"
* Cut-Out Diameter: 11-1/8"
Username: Logan__tille
AudioqueUSA
Post Number: 2086
in car audio you never go by peak power, always RMS. your subs are 25O rms each, you need and amp that will do 5OO rms. what is the voice coil config on your subs?
Damn where do I find that? I'll google it if anything.
AudioqueUSA
Post Number: 2087
and more watts does not equal louder.
My question is what's the best amp for this? When I see amps on ebay.. all I see is like 1000 watts, 1500 watts and such.
AudioqueUSA
Post Number: 2088
are they single voice coil or dual voice coil.
I have somewhere a Sony Xploid 600 Watt Amp.. Is that what I need 600/2= 300 Wat Each Sub?
AudioqueUSA
Post Number: 2089
whats your budget for an amp?
There single from what Im reading threw google.
Post Number: 7
100-150 Bucks? Give me a budget one.. then the best.
AudioqueUSA
Post Number: 2090
ok, im assumeing they are single voice coil 4 ohm. so you need an amp that does aroud 5OO RMS at 2ohm.
Post Number: 8
Which is the best..? You guys recommend them for me.
AudioqueUSA
Post Number: 2091
you could look on ebay for one of these...
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=474
Post Number: 9
Do I need a 2 channel or Mono like that one?
AudioqueUSA
Post Number: 2092
i doesnt madder, if you get a mono, you will wire them like this...Upload
if i was you i would get this...it is perfect for you.http://cgi.ebay.com/PHOENIX-GOLD-XENON-X400-1-400W-MONOBLOCK-AMPLIFIER-NEW_W0QQitemZ140045629818QQihZ004QQcategoryZ18797QQrdZ1QQcmdZViewItem?hash=item140045629818
Post Number: 10
I saw this.. Is this any good?
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15861
Username: Motomattic3
Post Number: 61
RMS= root means square Geez. lol
no but about "loadness" its senstiviy+10log(rms watts) and that will give you db. its not exact but it gives you an idea like a jl 12w6v2 for example its sensitivity is 85.9 and the rms watts is 400 so 85.9+10log(400)= 111.92
Post Number: 11
Aight.. Imma get it on my next paycheck.
Question.. what kind of wattage am I really getting from those subs?
Username: Tjmutlow
Post Number: 3090
you need to tell us if it has 1 voice coil or 2, it is where the wires run into the sub.
Post Number: 12
So.. let me ask another question.. are these subs gonna bump hard? Like be heard outside the car.. a good clean bass?
AudioqueUSA
Post Number: 2094
that amp is not very good.
Post Number: 13
It's one voice coil for each one. I bought two of them.
Username: Tjmutlow
Post Number: 3091
if that is a single 4ohm then a 2 ohm mono amp, if those are dual 4 ohm subs, get a mono 1 ohm or a 2 channel amp. do not buy a 2 channel amp for 2 single 4 ohm speakers.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3170
Ramses, they will sound clean and of course you're going to hear it outside the car, only if you're not deaf lol!
I think your budget is kinda low, so my best suggestion for you would be audiobahn a8000T.
Ramses, since you have interest for car audio, start reading from these three sites
www.bcae1.com
www.wickedcases.com (useful site from glasswolf)
And this in case you have some doubts about wiring subs.
www.the12volt.com
Ramses, do you know how to build boxes?? i hope you're not planning to buy those crappy boxes...
Talk to Wahl or one of these guys who knows about boxes, if i were you i'd talk to bassman3
Username: Tjmutlow
Post Number: 3094
then the audiobahn 8000t would be a good amp, and rather cheap on ebay...
Post Number: 14
Well I already bought the box.. cost me 40.00 I'll post a pic in a few..
Username: Juliob
Post Number: 3172
is the box sealed or ported? what's the tuning frequency?? many factors....
those subs will sound better sealed, but depends what kind of music do you like and how do you like the bass....
Do you like tight bass?
OR
do you like boomy bass??
Post Number: 15
Well I listen to Hip Hop Mostly.. I just like the bass to be loud so like people could know what your hearing outside. Make people turn heads you know?
That's the box.
http://img238.imageshack.us/img238/8111/hpim0239xk1.jpg
Username: Tjmutlow
Post Number: 3097
box is fine, but remember your only going to get so much out of it and also what type of car it is going in, a suv would sound better then in a trunk...
Post Number: 16
Yeah I own a toyota 4runner sr5. I just want it to bump outside and sound good.
Post Number: 18
So which amp would be better? the auditobahn 8000t or the audiobahn a8000t?
AudioqueUSA
Post Number: 2114
they are the same amp, someone just forgot the a.lol
AudioqueUSA
Post Number: 2115
didnt bring up my post.
Post Number: 19
Since I'm most likely gonna win the bid for the amp, which wiring kit do I need to hook it up?
Username: Tjmutlow
Post Number: 3103
4 guage is fine
Post Number: 20
Can you direct me to like a link to buy it.. remember I'm really new to all of this..
Username: Bernymac
AQ HD3!!, CA United States
Post Number: 712
ty mutlow said 4gauge. If you don't mind using ebay. look up stinger amp kit, with the 4gauge wiring. Since your new a amp kit is best. Remember Stinger. If your having problems just say so and I'll try looking it up.
Username: Bernymac
Post Number: 713
140045952551
thats the item number for a stinger 4gauge amp kit. its 62 bucks/free shipping. Might find lower so do some shopping.
Post Number: 21
Im having problems man.. I would appreciate if you found a link for me for it.
Post Number: 22
I see it on ebay now.. does monster cable make anygood wiring kits? Because when I go anywhere that's all I see.
Post Number: 23
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D140039979747&ssPageName=M ERC_VI_ReBay_Pr12_PcY_BIN_Stores_IT&refitem=140045952551&itemcount=12&refwidgetl oc=active_view_item&usedrule1=CategoryProximity&refwidgettype=cross_promot_widge t#ebayphotohosting
wouldent this work?
Post Number: 24
Or this?
http://cgi.ebay.com/PHONICS-4-GAUGE-1800W-AMPLIFIER-AMP-KIT-SPEAKER-WIRING_W0QQi temZ120044332151QQihZ002QQcategoryZ71528QQrdZ1QQcmdZViewItem#ebayphotohosting
Post Number: 25
So the Audiobahn A8000t Can power both of my JBL's gt4-12 ? What wattage am I going to get per sub?
Post Number: 26
Bump
AudioqueUSA
Post Number: 2125
monster is good.
AudioqueUSA
Post Number: 2126
yea, it will power both of your subs. they will each be getting around 4OO watts RMS.
Post Number: 29
Logan.. can you direct me to a good wiring kit cheaper than the ones someone suggested? Like in the 40 dollar range?
Username: Ctmike
Ct.
Post Number: 2182
$25.99:
http://www.knukonceptz.com/productDetail.cfm?prodID=eKo-K4
Post Number: 30
Hey Logan or Ctmike... someone outbidded me on the audiobahn.. searched and found this..? Same performance I'm getting from the audiobahn? What's the diff.
Keep in mind my subs are 250 RMS each with 1000 Peak Each one.
http://cgi.ebay.com/NEW-PIONEER-GM-7150M-MONO-CHANNEL-CH-AMPLIFIER-1CH-AMP_W0QQi temZ170043280618QQihZ007QQcategoryZ18797QQrdZ1QQcmdZViewItem
Username: Tjmutlow
Post Number: 3106
the audiobahn is better, try item number 220040083469 it is 157 delivered and the pioneer is about 107 delivered.
Post Number: 31
Ty.. can you tell me why it's better? More watt.. or why just better reliability?
Post Number: 32
Question.. why can't I get something like this?
http://cgi.ebay.com/Pyramid-PB1212X-1600W-2-1-Channel-Car-Audio-Amp-NEW_W0QQitem Z220042141580QQihZ012QQcategoryZ109254QQcmdZViewItem#ebayphotohosting
Post Number: 33
Nevermind that question.. I figured it out myself ^^ But why is the audiobahn better or not equal to the pioneer?
Post Number: 34
This one 800Watt RMS
http://cgi.ebay.com/LANZAR-800-WATT-RMS-1000w-MAX-CAR-STEREO-AMPLIFIER-AMP_W0QQi temZ270046287500QQihZ017QQcategoryZ18796QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
This one good?
Post Number: 35
I submitted a best offer for this amp
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=014&sspagename=STRK%3AMEBOFF%3A IT&viewitem=%26item%3D330042727850%26%26
Sounds good, at a decent price.
Username: Tjmutlow
Post Number: 3113
2nd link did not work and the lanzar is a 2 channel, wont work bridged mode for those subs unless you run stereo mode. remember 1 thing you get exactly what you pay for.the audiobahn is just a little better quality then those others.
Post Number: 36
Try this one.
Post Number: 37
The item number on ebay is:330042727850
Username: Tdawg30
Ohio USA
Post Number: 397
here is a very nice amp for cheap as you will find and awesome quality. I would get it before someone else does.
http://cgi.ebay.com/Memphis-16-ST500D-500W-Class-D-amplifier_W0QQitemZ3200431319 87QQihZ011QQcategoryZ18796QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Tdawg30
Ohio USA
Post Number: 398
this will do well too. http://cgi.ebay.com/KICKER-KX400-1-MONO-AMPLIFIER-400-WATTS-BEST-DEAL_W0QQitemZ1 80045151449QQihZ008QQcategoryZ79829QQrdZ1QQcmdZViewItem
Post Number: 38
Those are out of my price range right now.. how bout the last one I posted?
Username: Tdawg30
Ohio USA
Post Number: 400
no no no. Trust me you wont see over 100 watts out of that thing. I was fooled when I first got into car audio and bought one of those and my god it was the worst decision ever. so what is your price range???
you can get this. it says 800 @ 2ohms but its rated for 17volts so you will prolly get right around 500 out of it. only 102 bucks
http://cgi.ebay.com/MA-AUDIO-M1889I-800w-MONO-BLOCK-CAR-AMPLIFIER-POWER-AMP_W0QQ itemZ270048429755QQihZ017QQcategoryZ18797QQrdZ1QQcmdZViewItem
Post Number: 39
80 Bucks shipped is my limit. I'm dying to install it in my car, Im gonna try that amp... if it don't do well, I'll save up for a better one. But I need one to start out. Not only that I have to buy the wiring kit, and pay for the installation.
Yes I know I could do the installation myself, but for my car I have to remove all the panels.. and I dont wanna mess up anything and then have to pay my parents back for it. I rather take it to a pro, that way they mess it up..they pay.
Post Number: 40
Forget about the brandname.. is the wattage it's pumping out compatible for my 2 subs?
I tell you this because my friends have systems.. and there flea market/No name brands.. and they still thump hard.. I Dont want to hear the needle hitting the floor.. I just want to hear every beat bump hard in the back. Thats it.
Username: Tjmutlow
Post Number: 3119
then maybe you need to go to the flea market, or cash converters, but you can try item numbers 300042992929, or 300043965309, better then that cuspid amp....
Post Number: 41
Just read reviews on it.. screw it.. I gave him my best offer if he accpets It.. I wont pay it. Imma just end up buying the Audiobahn next week.
Post Number: 42
Which one of the last 2 is the best one? Those are perfect for me in my price range. Are they good quality?
Username: Tdawg30
Ohio USA
Post Number: 401
dude seriously you are better off saving another 15 and getting the MA. honestly save and do it right the first time. those boss amps wont do much.
Post Number: 43
The MA.. is the best quality?
Username: Tdawg30
Ohio USA
Post Number: 402
compared to the others yes.......it will put out the most watts for the money also.
Post Number: 44
aight I'll probably cop the Ma you showed me on friday..
Post Number: 45
Trevor thanks alot just purchased the amp. Now the wiring kit..
Username: Tdawg30
Ohio USA
Post Number: 403
alright an amp kit..... lets see here. how much you got to spend on it?
Post Number: 46
Let's say 30 bucks shipped?
Username: Tdawg30
Ohio USA
Post Number: 404
http://cgi.ebay.com/MDX-4-GAUGE-CAR-AUDIO-AMPLIFIER-SUBWOOFER-INSTALL-KIT_W0QQit emZ170044971808QQihZ007QQcategoryZ71528QQrdZ1QQcmdZViewItem
that should do.anything else you need????
Post Number: 47
Trevor.. can you show me just like picture of how there gonna wire it? Is it gonna be bridged or how? Remember I have 2 subs. Just show me a diagram of how it's gonna be done.
Username: Tdawg30
Ohio USA
Post Number: 428
the top one is how you should wire it.....
http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =2&impedance=SVC4
any other questions, just shoot away.
Post Number: 48
Trevor I think my subs are single voice coil.
Username: Tdawg30
Ohio USA
Post Number: 434
whoops I clicked on the wrong thing.......here you go....
Post Number: 49
I also forgot to mention that I'm connected all of this to a stock stereo. My stock stereo is a JBL Head Unit and bumps hard. Do I need anything else?
Username: Juliob
Post Number: 3236
Trevor you f*cked up his system with ma audio. They're so overrated and their quality isn't top notch. I'd have picked the audiobahn, it has better quality, a cooling fan and it holds extremely cool/hot temperatures.
Ramses i hope you enjoy it.
Even a profile would be a lot better than the MA
Post Number: 51
Yo Julio.. I read up on MA Audio.. everything Ive read about them is good. Let me ask you a question Julio, Im connecting the amp and subs to my factory head unit. I read up and saw I need a LOC.
I just went on ebay and purchased this item number. Item number: 140049157970
Does this work good?
Username: Juliob
Post Number: 3241
doesn't matter too much the brand of the LOC, you just need the LOC ramses. I hope you enjoy your lil system. Is nice and should sound clean.
Post Number: 52
If I recieve everything by thursday, then friday morning Im taking it for the install. I'll tell you how it sounds, and take some video of it, and place it on youtube.
I'm already thinking about a system for next year. I'm going to save up and buy Alpine Type R's. Ive seen so many video's on youtube. Those things look crazy! I'mma buy also a alpine headunit, and I got to see what amp, powers them up good to give them that huge bass I see in videos.
Here's a example:
http://youtube.com/watch?v=6qiBw3JkNQo
I want that crazy bass!
Username: Juliob
Post Number: 3243
that box might be tuned to 60 HZ lol!
and why are you so sure they're type Rs lol!
It must be a biga$$ box with huge ports
Post Number: 53
Why am I sure... Don't know but he states it in the begining of the video they are 2 12" Type R's.
What are huge ports? The spaces for ventilation?
Post Number: 54
I like to thank everyone who helped me. I took everything to get installed today, and it exceded my expectations. The bass is incredible, and two of my friends that their flee market system was the "ish"
they now envy mine.
Username: Juliob
Post Number: 3349
enjoy it!
