SPL SUB...recommendations PLZ!
Username: Trey4sports
Post Number: 16
well right now i have a concept audio csp 15 with these specs...i want a sub with the most spl for under 800 or so, my question is with this sub will i be better off keeping it or can i do alot better for 6-800?
8000 watt max (2000 x 4)
Peak power handling: 2000 Watts per voice coil
Continuous power handling: 1000 Watts per voice coil
Impedance: QuadCoilf- 1 ohm (4 X 1 ohm)
4" black anodized Aluminum voice coil former with Kapton layered protection
450 -oz magnet structure
FEA (Finite Element Analysis)
Computer-optimized aluminum basket
Extra large 10" Poly/Cotton/Nomex spider for maximum excursion
SRSf Patent Pending Voice Coil centering device
1.25" thick top plate for optimized flux flow and motor strength
High-density 2.25" wide big foam surround
Ultra Rigid/Ultra Thick "pulped" paper cone
Rubber-Toughen isolated high current Tinsel lead wire
Patent pending CWACf technology prevents Tinsel lead wire rattle and destruction
Silver-plated spring loaded binding posts
Custom engraved bottom plate
Designed and built in U.S.A.
Username: Drivingreckless
\red {TREO}, \orange {USA} \3 {soon to ...
Post Number: 2202
my dual 2 treo ssx for 450 shipped 15"
Post Number: 2203
pix
http://upload4.postimage.org/986684/photo_hosting.html
http://upload4.postimage.org/986686/photo_hosting.html
http://upload4.postimage.org/986740/photo_hosting.html
Username: Bump05
Hesperia, CA USA
Post Number: 218
18" btl fully loaded
Username: Logan__tille
AudioqueUSA
Post Number: 2377
His SSX^^
Post Number: 17
what are the specs for the ssx?
Post Number: 18
Post Number: 2206
http://treoonline.com/ssx.html
got to the bottom were it says view specifications
i have the 15"
they sell at local shops for 870
Post Number: 19
...my godd...thats gotta be some of the craziest SPL subs ive seen, so drivingreckless are these still under warranty ? btw wat kind of DB's have u hit with this setup?
Post Number: 2208
i hit 144dbs
and no NO warrenty
BUT i will gaurenntee it to be AGAINST DOA
which means wen it arrives at ur house it will be in perfect working order
Post Number: 20
welll i love the setup but by no means hold it for me or anything because i have alot of things to clear up/ sell but its very intriguing, i would think that the subs could hit 155-160 DB tho, im new to car audio but 4 inch excursion and 530 oz magnet per sub seems like a huge huge sub, maybe i read it wrong tho?
Username: Extrmndor3
Life is GOOD, Ill Us
Post Number: 2495
damn trey u really know about db's ull definately be hittin 160 db's easily :-)
Post Number: 2209
i only have one 15" not 4 bro 155 is harder to hit then u beleive alot of time effort and installations have to be put into ur car flawlessly and patiently
but let me no bout the sub
Post Number: 22
ohh i gotcha ill prolly just stick with my sub for the time being but if something changes ill let you know. thanks for the idea tho
Post Number: 23
i thought driving reckless was selling 2 15's thats why i insinuated 144DB seemed a bit conservative
